- From: Casteran Pierre <pierre.casteran AT labri.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] problem with hlists
- Date: Thu, 29 Aug 2013 13:30:25 +0200
- Organization: LaBRI - Université Bordeaux 1 - France
Hi,
Using cpdt's hlists, I had to define a function
hset (y:B elm): forall (l:list A)(M:member l) , hlist l -> hlist l.
such that (hset y M hl) returns hl with y at the place defined by M.
I got some solution, but in an interactive definition, using inversion twice. Is there a direct solution (as a variation on hget), making
easy to prove for instance that (hget (hset y M hl)) M = y ?
Pierre
Require Import List. (* from cpdt *) Section hlist. Set Implicit Arguments. Variable A : Type. Variable B : A -> Type. Inductive hlist : list A -> Type := | HNil : hlist nil | HCons : forall (x:A)(ls : list A), B x -> hlist ls -> hlist (x::ls). Variable elm : A. Inductive member : list A -> Type := | HFirst : forall ls, member (elm :: ls) | HNext : forall x ls, member ls -> member (x::ls). (** puts y at the position defined by M *) Definition hset (y:B elm): forall (l:list A)(M:member l) , hlist l -> hlist l. intros l M;induction M. inversion_clear 1 as [|x0 x1]. exact (HCons y X1). intro hs; inversion_clear hs . exact (HCons X (IHM X0)). Defined. (** from cpdt again *) Fixpoint hget ls (mls : hlist ls) : member ls -> B elm := match mls with | HNil => fun mem => match mem in member ls' return (match ls' with | nil => B elm | _::_ => unit end) with | HFirst _ => tt | HNext _ _ _ => tt end | HCons _ _ x mls' => fun mem => match mem in member ls' return (match ls' with | nil => Empty_set | x' :: ls'' => B x' -> (member ls'' -> B elm) -> B elm end) with | HFirst _ => fun x _ => x | HNext _ _ mem' => fun _ get_mls' => get_mls' mem' end x (hget mls') end. Goal forall (y:B elm)(l:list A)(M:member l)(hl:hlist l), (hget (hset y M hl)) M = y. Admitted. End hlist.
- [Coq-Club] problem with hlists, Casteran Pierre, 08/29/2013
- Re: [Coq-Club] problem with hlists, Adam Chlipala, 08/29/2013
