coq-club - Re: [Coq-Club] CoqIde crash on Eval compute
  • To: Rui Baptista <rpgcbaptista AT gmail.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] CoqIde crash on Eval compute
  • Date: Sat, 31 Aug 2013 10:22:33 -0300
Hi Rui,
Thanks for the reply. Here it is. Just try to execute the last line.
Require Import Ascii.
Require Import String.
Require Import Compare_dec.
Open Scope string_scope.
Definition b0: bool := false.
Definition b1: bool := true.
(* CONVERT ASCII TO STRING *)
Definition chr_to_str (c: ascii): string :=
   match c with
   | Ascii b0 b0 b0 b0 b1 b1 b0 b0  => "0"
   | Ascii b1 b0 b0 b0 b1 b1 b0 b0  => "1"
   | Ascii b0 b1 b0 b0 b1 b1 b0 b0  => "2"
   | Ascii b1 b1 b0 b0 b1 b1 b0 b0  => "3"
   | Ascii b0 b0 b1 b0 b1 b1 b0 b0  => "4"
   | Ascii _  _  _  _  _  _  _  _   => "#"
   end.
Definition nat_to_str (n: nat): string :=
   chr_to_str (ascii_of_nat (n+48)).
(* STATES *)
Definition state: Type := (nat*bool*bool)%type.
(* STATE NAME PRINT*)
Definition state_name_print (n: nat): string :=
"q" ++ nat_to_str n.
(* STATE PRINT *)
Fixpoint state_print (q: state): string :=
   match q with
   | (n,i,f) => state_name_print n
   end.
(* STATE SETS *)
Inductive state_set: Type :=
   | sset_empty: state_set
   | sset_item: state->state_set
   | sset_build: state->state_set->state_set.
(* STATE SET PRINT *)
Fixpoint state_set_print (s: state_set): string :=
   match s with
   | sset_empty => ""
   | sset_item st => "
" ++ state_print st
   | sset_build st s' => "
" ++ state_print st ++ state_set_print s'
   end.
(* INSERT STATE IN AN ORDERED SET *)
Fixpoint insert_state (q: state)(s: state_set): state_set :=
   match s with
   | sset_empty => sset_item q
   | sset_item q' => match q, q' with
                     | (n,i,f),(n',i',f') => if leb n n'
                                                then sset_build q (sset_item q')
                                                else sset_build q' (sset_item q)
                     end
   | sset_build q' s' => match q, q' with
                                                then sset_build q s
                                                else sset_build q' (insert_state q s')
                         end
   end.
(* SORT STATE SET *)
Fixpoint sort_state_set (s: state_set): state_set :=
   match s with
   | sset_empty => sset_empty
   | sset_item q => s
   | sset_build q s' => insert_state q (sort_state_set s')
   end.
(* BUILD A NUMBER BASED ON THE NUMBERS OF THE STATES IN THE ORDERED STATE SET *)
Fixpoint build_state_number (s: state_set): nat :=
   match s with
   | sset_empty => O
   | sset_item (n,i,f) => n
   | sset_build (n,i,f) s' => (build_state_number s')*10+n
   end.
Definition est0: state := (0,false,false).
Definition est1: state := (1,false,false).
Definition est2: state := (2,false,false).
Definition est3: state := (3,false,false).
Definition est4: state := (4,false,false).
Definition eset: state_set :=
sset_build est4 (
sset_build est3 (
sset_build est2 (
sset_build est1 (
sset_item est0)))).
(* SHOULD PRINT STRING Q4 Q3 Q2 Q1 Q0 *)
Eval compute in state_set_print eset.
(* SHOULD PRINT STRING Q0 Q1 Q2 Q3 Q4 *)
Eval compute in state_set_print (sort_state_set eset).
(* SHOULD PRINT NAT 43210 *)
Eval compute in build_state_number (sort_state_set eset).
Regards,
Marcus.
2013/8/31 Rui Baptista <rpgcbaptista AT gmail.com>
That is a bug. Maybe if you include more information in some match-with-end pattern, you can get around it. Here are some examples:
(* without wildcards, with as-in-return, type-checks *)
Fixpoint le_pred (n1 n2 : nat) (H1 : n1 <= n2) : pred n1 <= pred n2 :=
  match H1 in _ <= n2 return pred n1 <= pred n2 with
  | le_n      => le_n (pred n1)
  | le_S n2 H1 =>
    match n2 as n2 return pred n1 <= pred n2 -> pred n1 <= pred (S n2) with
    | 0   => fun H2 => H2
    | S n3 => fun H2 => le_S (pred n1) (pred (S n3)) H2
    end (le_pred n1 n2 H1)
  end.
(* without wildcards, without as-in-return, doesn't type-check *)
  match H1 with
  | le_S n2 H1 =>
    match n2 with
    | 0   => fun H2 => H2
  end.
(* with wildcards, with as-in-return, type-checks *)
  | le_n => le_n _
  | le_S n2 H1 =>
    | 0 => fun H2 => H2
    | S _ => fun H2 => le_S _ _ H2
    end (le_pred _ _ H1)
  end.
(* with wildcards, without as-in-return, stack-overflows *)
  match H1 with
  | le_n => le_n _
  | le_S n2 H1 =>
    match n2 with
    | 0 => fun H2 => H2
  end.
