coq-club - Re: [Coq-Club] Pattern tactic that generates [let...in...]
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Pattern tactic that generates [let...in...]
  • Date: Tue, 3 Sep 2013 19:46:40 -0400
Hi, Jason --
That is producing the right term but it requires a lot of goal manipulation and I haven't found a good way use those kinds of tactics to construct the term that I want and then return them to be used by other tactics.
On Tue, Sep 3, 2013 at 5:57 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Does [let x := fresh in set (x := bar); try revert x] do what you want?
-Jason
On Tuesday, September 3, 2013, Gregory Malecha wrote:
Hello --
I have a term [foo] with a lot of occurances of a large subterm [bar]. I would like to abstract all of the instances of [bar] and produce a term like:
let x := bar in foo[bar |-> x]
One way to do something like this is with the [pattern] tactic, but this fails when there is dependency on [bar] since it is constructing a lambda abstraction, i.e. it constructs:
(fun x =>  foo[bar |-> x]) bar
I have a plugin/patch that achieves the former but I am wondering if there is an existing way to do it that I don't know about.
Thank you very much.
gregory malecha
