coq-club - Re: [Coq-Club] Re: handling duplicated names for definitions
  • From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • To: Leonardo Rodriguez <leonardomatiasrodriguez AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Re: handling duplicated names for definitions
  • Date: Mon, 9 Sep 2013 09:59:37 +0200
You can certainly define Module Short := LongName.
On 8 September 2013 22:18, Leonardo Rodriguez <leonardomatiasrodriguez AT gmail.com> wrote:
I meant "Other" instead of "B" in the last Import.
2013/9/8 Leonardo Rodriguez <leonardomatiasrodriguez AT gmail.com>
Hi CoqClub,
This is a beginner's question. Suppose you have two files:
LongName.v
   Inductive an_inductive_type :=
      a_constructor : an_inductive_type
Other.v
(same names!)
Combined.v
Require Import LongName
Require Import B
Inside the file Combined, the only way I know of indicate to Coq which one is the
constructor I want is by using LongName.a_constructor.  But I wonder if there is a better way, like giving a scope name as we do with Notations. Or giving a shorter alias to LongName.v. Not sure if the Module system (I never used it) could help me.
Thank you.
