- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Fwd: Question about recursion and induction
- Date: Sat, 14 Sep 2013 15:29:17 +0300
Sorry, I previously sent it only to Adam Chlipala.
---------- Forwarded message ----------
Date: Sat, Sep 14, 2013 at 12:32 PM
Subject: Re: [Coq-Club] Question about recursion and induction
To: Adam Chlipala <adamc AT csail.mit.edu>
Yes, it seems like a direct match but it didn't help me enough.
This is how far I got:
Require Import Omega.
Definition nz: Set := {n:nat | n<>O}.
Theorem nz_t1 (n:nat): S n<>O. Proof. auto. Qed.
Definition nz_eq (n m:nz) := eq (projT1 n) (projT1 m).
Definition nz_one: nz := exist _ 1 (nz_t1 O).
Definition nz_lt (n m:nz) := lt (projT1 n) (projT1 m).
Definition nz_pred (n:nz): nz := exist _ (S (pred (pred (projT1 n)))) (nz_t1 _).
Theorem nz_Acc: forall (n:nz), Acc nz_lt n.
Proof.
intro. destruct n as [n pn], n as [|n]. omega.
induction n; split; intros; destruct y as [y py]; unfold nz_lt in *; simpl in *.
omega.
assert (y<S n\/y=S n). omega. destruct H0.
assert (S n<>O); auto.
assert (nz_lt (exist _ y py) (exist _ (S n) H1)). unfold nz_lt; simpl; assumption.
fold nz_lt in *. apply Acc_inv with (exist (fun n0:nat=>n0<>O) (S n) H1). apply IHn.
rewrite <- H0 in IHn. apply IHn.
Defined.
Theorem nz_lt_wf: well_founded nz_lt. Proof. exact nz_Acc. Qed.
Lemma pred_wf: forall (n m:nz), nz_lt nz_one n -> m = nz_pred n -> nz_lt m n.
Proof.
intros. unfold nz_lt, nz_pred in *. destruct n as [n pn], m as [m pm]. simpl in *.
destruct n, m; try omega. simpl in *. inversion H0. omega.
Defined.
And then I have no idea what to do because mergeSort example seems too complicated.
On Sat, Sep 14, 2013 at 1:13 AM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
Have you read Chapter 7 of CPDT <http://adam.chlipala.net/cpdt/>? Especially Section 7.1 seems like a fairly direct match with your question.
On 09/13/2013 05:34 PM, Ilmārs Cīrulis wrote:Let's suppose that I have
- type T- wellfounded relation R: T->T->Prop- function F1: T->T that makes argument "smaller"- condition C: T->Prop that describes "start values" of R- function F2: T->T that makes argument "bigger"
How can I make Fixpoint that looks similar to this:
Fixpoint Example (n:T):X :=match {C n} + {~C n} withleft _ => ... |right _ => Example (F1 n)end.
And how I can make possible the following usage of tactic 'induction' (or similar):
Theorem ...Proof....induction n F.(* And now I have two goals:the first with assumption C n and goal P n,the second with assumption P n and goal P (F2 n) *)...Qed.
- [Coq-Club] Question about recursion and induction, Ilmārs Cīrulis, 09/13/2013
- Re: [Coq-Club] Question about recursion and induction, Adam Chlipala, 09/14/2013
- Message not available
- [Coq-Club] Fwd: Question about recursion and induction, Ilmārs Cīrulis, 09/14/2013
- Re: [Coq-Club] Fwd: Question about recursion and induction, Rui Baptista, 09/14/2013
- Re: [Coq-Club] Fwd: Question about recursion and induction, Ilmārs Cīrulis, 09/15/2013
- Re: [Coq-Club] Fwd: Question about recursion and induction, Adam Chlipala, 09/15/2013
- Re: [Coq-Club] Fwd: Question about recursion and induction, Rui Baptista, 09/15/2013
