- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Extracting Value from a Monad
- Date: Sun, 15 Sep 2013 07:16:43 +0000
Hi,
Consider the following code in Mtac.Definition when_has_value1 (p: option Prop) := match p with | None => True | Some p' => p' end. Definition when_has_value2 (p: M Prop) := match p with | ret p' => p' | _ => True (* there was an exception *) end.The first function extracts a value from the option Monad -- if there is a prop, we return the prop. Otherwise, we return true.
The second definition attempts (but does not compile) to extract a value from the M monad -- however it doesn't work. I feel like I'm doing something ridiciously stupid and there's a trivial fix -- how do I get the second function to work?
Thanks!
- [Coq-Club] Extracting Value from a Monad, t x, 09/15/2013
