- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] auto / Hint Extern
- Date: Sat, 21 Sep 2013 19:27:09 +0200
Hi,
Le 21/09/2013 18:25, t x a écrit :
> To check if I understand your logic correctly --
> Suppose we defined "agressive_auto" =
> // this is probably not really correct
> repeat (
> forall x in Hint Extern (sorted by precedence);
> if we can apply x, apply x
> Then basically, the property of "don't change state if it can't be proved"
> can
> be simulated with:
> solve[ agressive_auto ];
> and the property of never fail can be simulated with
> try( solve [ agressive_auto ] );
> in which case, auto "sorta =" try (solve [agressive_auto]) ?
What you suggest would work only when there is only one possible path (or no
backtracking).
Best,
Cyril Cohen
- [Coq-Club] auto / Hint Extern, t x, 09/21/2013
- Re: [Coq-Club] auto / Hint Extern, AUGER Cédric, 09/21/2013
- Re: [Coq-Club] auto / Hint Extern, t x, 09/21/2013
- Re: [Coq-Club] auto / Hint Extern, Cyril Cohen, 09/21/2013
- Re: [Coq-Club] auto / Hint Extern, Pierre Courtieu, 09/21/2013
- Re: [Coq-Club] auto / Hint Extern, Jason Gross, 09/21/2013
- Re: [Coq-Club] auto / Hint Extern, t x, 09/23/2013
- Re: [Coq-Club] auto / Hint Extern, Jason Gross, 09/23/2013
