- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: "Marcus Ramos" <mvmramos AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "compute" returns "invalid argument" in proof only
- Date: Fri, 27 Sep 2013 15:29:34 +0200
Hi,
This not usual. I would guess that your problem is something like
you ask
Eval compute in (fun (x : foo) => bar x)
and that's immediate but in the hypothesis of your proof you don't have
x : foo
but
x := term_that_allow_very_heavy_computation : foo
so
compute "bar x" -> compute "bar term_that_allow_very_heavy_computation" takes
ages
It is impossible to make more useful comments without a concrete example of
your problem.
All the best,
Pierre B.
Le 26 sept. 2013 à 02:37, Marcus Ramos
a écrit :
> Hi,
> When I issue an "Eval compute" on a term with a call to a single Fixpoint,
> the
> answer is almost immediate.
> When I issue "compute" (for the same Fixpoint with the same arguments)
> inside
> a proof for a theorem, it takes a long while (>15 minutes) and finally I get
> the message "Invalid argument" (stack overflow?). Because of this, I can´t
> complete the proof of the theorem.
> Is this usual? Any hints why this happens? How could I trace the problem and
> fix it? I am using coqIDE 8.4pl1 in Windows 8.
> Thanks in advance,
> Marcus.
- [Coq-Club] "compute" returns "invalid argument" in proof only, Marcus Ramos, 09/26/2013
- Re: [Coq-Club] "compute" returns "invalid argument" in proof only, Pierre Boutillier, 09/27/2013
