- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] questions about real numbers in Coq
- Date: Tue, 1 Oct 2013 14:42:05 +0200
2013/10/1 Jason Gross <jasongross9 AT gmail.com>
Hmm, wouldn't it be better to say that "the irrationals are dense in the reals"? As far as I remember, "X is dense IN Y" implies that X is a subset of Y (else, they are not "<some property> IN").
And for that last proof, it should not be hard. Take two rationals x and y such that x<y, x+π⁻¹×(y-x) is irrational (else by stability of the usual operations, that would mean that ((x+π⁻¹×(y-x))×(y-x)⁻¹-x)⁻¹ = π would be rational.
Furthermore, as 0<π⁻¹<1, 0<π⁻¹×(y-x)<y-x, and so x<x+π⁻¹×(y-x)<y.
I assume that by "dense", the desired theorem is that between every two non-equal rational numbers there's a real number. This is very easy, though: just convert their average to a real number. Alternatively, you might want the theorem that the irrationals are dense in the rationals (between every two non-equal rationals there is an irrational); I don't know how to prove this).
-Jason
On Tuesday, October 1, 2013, Jacques-Henri Jourdan wrote:Le 01/10/2013 07:51, Lucian M. Patcas a écrit :
Hi,
I have a few questions about real numbers in Coq:
1. Is there a notation for concrete real numbers in Coq, e.g. how can I write 10.55 in Coq?
There is the Q2R function to convert a rational to a real.
2. Is there a theorem or an axiom in the Standard Library that the real numbers are dense? (perhaps I managed to miss it)
What do you mean by dense ? There is the completeness axiom and the R_complete theorem that states that every Cauchy sequence converges.
3. Is anyone aware of a proof in Coq that the real numbers are dense?
Thanks,
Lucian
JH
.../Sedrikov\...
- [Coq-Club] questions about real numbers in Coq, Lucian M. Patcas, 10/01/2013
- <Possible follow-up(s)>
- Re: [Coq-Club] questions about real numbers in Coq, Jacques-Henri Jourdan, 10/01/2013
- Re: [Coq-Club] questions about real numbers in Coq, Jason Gross, 10/01/2013
- Re: [Coq-Club] questions about real numbers in Coq, Cedric Auger, 10/01/2013
- Re: [Coq-Club] questions about real numbers in Coq, Daniel Schepler, 10/01/2013
- Re: [Coq-Club] questions about real numbers in Coq, Lucian M. Patcas, 10/01/2013
