coq-club - Re: [Coq-Club] Program and branching informations
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Program and branching informations
  • Date: Wed, 2 Oct 2013 11:39:34 +0200
Hi,
Thank you! It's exactly what I wanted.
Fabien
On Tue, Oct 1, 2013 at 11:40 AM, Matthieu Sozeau <matthieu.sozeau AT gmail.com> wrote:
Hi,
  You can use the 'dec' combinator from Program's Coq library to get the equality
corresponding to the if statement in each branch. E.g. "if dec (eq_nat n 3) then _ else _"
-- Matthieu
On 1 oct. 2013, at 10:06, Fabien Renaud <fafounet AT gmail.com> wrote:
> Hi,
> Here is a simplification of my problem:
> Fixpoint eq_nat (m n : nat) : bool :=
> match m, n with
> | 0, 0 => true
> | S m', S n' => eq_nat m' n'
> | _,_ => false
> end.
> Program Fixpoint test (n: nat) :=
> match n with
> | 0 => 0::nil
> | S n => if (eq_nat n 3) then _ else _
> end.
> Program asks me to fill 2 obligations. In this case this is fine. I know which obligation is asked in which order.
> However sometimes the situation is a bit more complex and I have to perform a proof, and not only refine.
> And the problem is that I lack the information about in which branch of the "if" I am. And thus I cannot conclude my proof since
> I cannot remove some contradictory cases.
> Does someone have an idea?
> Thanks!
> Fabien
