coq-club - Re: [Coq-Club] "minimal" set of tactics
  • From: Kristopher Micinski <krismicinski AT gmail.com>
  • To: t x <txrev319 AT gmail.com>
  • Cc: Jason Gross <jasongross9 AT gmail.com>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] "minimal" set of tactics
  • Date: Mon, 7 Oct 2013 10:22:46 -0400
In fact, this is basically what is done in Agda (for example), where you build all the proof terms without tactics.
Kris
On Mon, Oct 7, 2013 at 2:13 AM, t x <txrev319 AT gmail.com> wrote:
Ah, that's right, all the tactics are just to help me build an _expression_ of a certain type.
Thanks! :-)
On Sun, Oct 6, 2013 at 9:50 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
You don't actually need any tactics; you can do anything with only [Definition.]  Alternatively, your minimal set of tactics is {[exact]}.
-Jason
On Monday, October 7, 2013, t x wrote:
Hi,
  Let $S$ be a "minimal" set of tactics, if (1) any proposition provable in Coq can be proved using only $S$ and (2) removing a tactic from $S$ makes (1) false.
  My question: is "pattern at, apply, cbv, inversion, assert, f_equal, unfold, fold" enough?
  For example:
    replace _ with _ ==> assert( _ = _ ) + rewrite ...
    rewrite ==> pattern at ....  + f_equal
    simpl ==> cbv ...
    destruct ==> inversion
  This leads me to believe that the above is sufficient. However, is it "minimal", or we can remove some more from it?
Thanks!
