- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Dimitri Hendriks <diem AT xs4all.nl>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] equality between dependent pairs
- Date: Tue, 8 Oct 2013 12:57:21 +0200
Well, proof irrelevance is one way. But in that particular case you can rephrase in an appropriate way Q to use that the condition is decidable:
supposing a test bgt : nat -> nat -> bool for strict comparison, and beq for equality (for instance those defined in the number library http://coq.inria.fr/distrib/current/stdlib/Coq.Numbers.Natural.Peano.NPeano.html ).
Q := { x : nat*nat | ( let (a,b) := x in bgt a 0 && bgt b 0 /\ beq (gcd a b) 1 ) = true }
The trick, now, is that forall (b1 b2:bool) (p q:b1 = b2), p=q as mentioned in the faq items you cite (using Coq.Logic.Eqdep_dec.UIP_dec in conjunction with Coq.Bool.Bool.bool_dec).
From there, it is a simple exercise to prove that
forall x y:Q, proj1_sig x = proj1_sig y -> x = y
On 8 October 2013 12:07, Dimitri Hendriks <diem AT xs4all.nl> wrote:
Hi all,I have functions valq : list two -> Q and locq : Q -> list two, where two is a two-element set, and Q is the sigma typeQ := { x : nat*nat | let (a,b) := x in a > 0 /\ b > 0 /\ gcd a b = 1 }.I have that valq is injective. Now for surjectivity I want to show that locq is a right-inverse of valq, i.e., forall r:Q, valq (locq r) = r. So I have to deal with equality between dependent pairs ... Do I need proof irrelevance, or can I somehow use that > and = are decidable on nat (as suggested by the answers to faq 38 and 138)? Any alternatives?Further info: valq and locq are based on val : list two -> nat*nat, loc : nat*nat -> list two, and it holds that forall a b, a > 0 -> b > 0 -> gcd a b = 1 -> val (loc (a,b)) = (a,b) .Thanks for your suggestions,Dimitri
- [Coq-Club] equality between dependent pairs, Dimitri Hendriks, 10/08/2013
- Re: [Coq-Club] equality between dependent pairs, Arnaud Spiwack, 10/08/2013
- Re: [Coq-Club] equality between dependent pairs, Robbert Krebbers, 10/08/2013
- Re: [Coq-Club] equality between dependent pairs, Dimitri Hendriks, 10/09/2013
