- To: Thomas Braibant <thomas.braibant AT gmail.com>
- Cc: t x <txrev319 AT gmail.com>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Package managing
- Date: Mon, 14 Oct 2013 16:07:14 +0200
I once did the following back-of-the-envelope computation:
http://qa.debian.org/popcon.php?package=coq
1210 installations
http://popcon.ubuntu.com/by_inst
5697 installations!
To complete the statistics you would need to have a distribution of
operating systems.
http://distrowatch.com/
There should be more than 20,000 *linux* installations of Coq!
Maybe 50,000 installations in total ????
I am sure someone will correct these numbers.
On Mon, Oct 14, 2013 at 4:00 PM, Thomas Braibant
wrote:
> Hi,
> I am not sure at all about that, because the space of installed packaged may
> become quite big (if you consider one image per possible subset of installed
> packages).
> Yet I still find the suggestion very interesting in a slightly different
> context: Coq is widely [1] used in academia. It might be very nice to
> package a given Coq version, with a given set of package as a Dockerfile
> script, and provide that for students. It would be a nice and easy way to
> get everyone use the same setup, when giving a Coq class. (BTW, this rings a
> bell, so maybe it already exists).
> [1] This is a personal opinion, on which I would love to get precise numbers
> Thomas
> On Sun, Oct 13, 2013 at 2:34 AM, t x
> wrote:
>> One thing possibly worth considering might be docker.io -- they use copy
>> on write file systems, so one can create a base ubuntu + ocaml image, and
>> the various Coq installations are "diffs" against the base image.
>> Each "package" then becomes a Dockerfile script which builds the variant
>> of Coq.
>> On Sat, Oct 12, 2013 at 2:59 PM, Thomas Braibant
>> wrote:
>>> Hi list,
>>> Last summer, I have been playing around a prototype package manager
>>> for Coq. It is really a prototype and not ready for public consumption,
>>> but it raised some interesting questions that need feedback.
>>> The main ideas behind this prototype are 1) to be able to "switch"
>>> between various versions of Coq, without having to
>>> recompile/reinstall/handle symlinks by hand in any way; 2) to have a
>>> unified way to find out what packages (that is, libraries, plugins,
>>> fancy developments) are available for a given version of Coq; 3) to
>>> get this prototype working with as little work as possible.
>>> My solution to 1), 2) and 3) was to hack opam, the OCaml package
>>> manager, to use it to handle Coq installations rather than OCaml
>>> installations. Many thanks to ocamlpro for the brilliant tool that
>>> opam is.
>>> Now for the questions/request for comments.
>>> * What about camlp4/camlp5?
>>> Some packages (ssreflect 1.5rc1) do not compile if Coq was not
>>> compiled with camlp5. I do not know of packages that require camlp4
>>> specifically. Is there a good reason to handle both, or should
>>> camlp5 be mandatory?
>>> * Build systems
>>> All packages I know of either use hand-written makefiles, or
>>> coq_makefile generated one. Do you use something fancier?
>>> * Installation of packages
>>> Some packages are meant to be installed "locally". That is, they ask
>>> the user to add a few cryptic commands to files, like:
>>> Add Rec LoadPath "<dir>" as FooBar.
>>> The problem with that is that it makes for non-portable
>>> developments. It seems a rather fragile way to mark dependencies on
>>> packages, and prone to break if one distribute files: there is no
>>> reason that the <dir> path I use will be valid on someone else's
>>> computer.
>>> Then, coq_makefile generates Makefiles with an "install target" that
>>> copy required files (plugins and .vo) to coq/user-contrib/foobar/
>>> (where foobar is the name of the package). This seems portable,
>>> since coqtop will look there upon "Require".
>>> Is there any reason not to make this mandatory for packages? It
>>> would make for an easy uninstall procedure, since it suffices to
>>> remove the foobar directory to remove the foobar package. (I am not
>>> speaking of dependencies between packages here, because this is
>>> nicely handled by the prototype).
>>> * Coq contribs, and packages in the wild
>>> Coq contributions housed at http://coq.inria.fr/pylons/contribs made
>>> for a mixed experience when I tried to package some of them. Some
>>> work out of the box, once you figure what are the INSTALL steps.
>>> Some are harder to handle. For instance, the ergo contrib has its
>>> dependencies over other contribs built in its makefile, which
>>> requires some work (it is not an "out-of-the-box" experience).
>>> Then, there are some outstanding works that are not present there at
>>> all, or that are old versions of things. I spent some time trying to
>>> find out packages in the wild, but this is a place where help is
>>> needed. If you have a package, and you think it could be cool to add
>>> it to this prototype package manager, please, send me an email.
>>> * (Simplifying) design decisions.
>>> First, if you would be happy with recompiling everything
>>> anytime you switch from compilers to compilers, there is no need for
>>> a dedicated package manager, you can use opam readily for that, with
>>> the right list of packages. Yet, I really think that we want some
>>> "persistent" coq switches: switching from coq vA to coq vB makes it
>>> possible to install packages for vB, and come back to your coq vA
>>> installation without having to recompile coq vA. (Personally, I used
>>> to think that I would only ever use the latest Coq version, but it
>>> is not the case anymore: sometimes, I use trunk, sometimes I use Coq
>>> patched with mtac, sometimes, I use 8.4pl2 and so on.) So am I right
>>> that we (the coq community) want some persistent switches?
>>> Second, changing the underlying OCaml version will force the user to
>>> recompile his Coq installations and packages. There may be a spot
>>> for discussion here, because I think that vo's magic number depends
>>> on the ocaml version, which may be too stringent. Yet, it is no big
>>> deal, is it?
>>> Third, after discussion with OCamlPro people, it seems that it could
>>> be possible to enhance opam to be our Coq package manager (Coq
>>> packages would get a special treatment). Would people be happy with
>>> that kind of workflow? Or would you rather have a separate package
>>> manager, maybe a fork of opam (which is what my prototype is)?
>>> * compilers and packages.
>>> So far, my list of packages and compilers are as follows.
>>> aac_tactics.0.4 containers.2010 ergo.2010 mathcomp.1.5
>>> color.09.09.2013 counting.2010 flocq.2.2.0 ssreflect.1.5
>>> compcert.2.0 cybelle.1.2 interval.0.16.1
>>> 8.4.dev 8.4.pl1-mtac 8.4.pl2-mtac 8.4.pl2 trunk
>>> If you have a package/a coq version that you would like to see on
>>> this list, please let me know privately. Note that this list is the
>>> product of a random process, and that some packages (some of my own
>>> even)
>>> are not part of it yet. I think we really need to be
>>> "consumer-driven" here [1].
>>> (There might be a naming issue, because some packages are not
>>> versioned officialy, and/or I mangled names. I think it is
>>> not really important at this point, isn't it?)
>>> To conclude this email, I think that building this list of packages and
>>> compilers that can be installed in an automatic manner is an important
>>> part of the job, and help is needed on that front. Then, there is the
>>> actual code of the package manager: it seems that OCamlPro is willing
>>> to help, and I would like personally to continue to work on it in my
>>> spare time [2]. But if you want to help, please let me know.
>>> Thomas
>>> [1] For instance, on my todo list are the various libraries about
>>> separation logic
>>> that I know of.
>>> [2] Even if my spare time is a dwindling quantity recently.
- [Coq-Club] Package managing, Thomas Braibant, 10/12/2013
- Re: [Coq-Club] Package managing, t x, 10/13/2013
- Re: [Coq-Club] Package managing, Thomas Braibant, 10/14/2013
- Re: [Coq-Club] Package managing, Bas Spitters, 10/14/2013
- Re: [Coq-Club] Package managing, Enrico Tassi, 10/14/2013
- Re: [Coq-Club] Package managing, Gregory Malecha, 10/13/2013
- Re: [Coq-Club] Package managing, Enrico Tassi, 10/13/2013
- Re: [Coq-Club] Package managing, Jason Gross, 10/13/2013
- Re: [Coq-Club] Package managing, Cyril Cohen, 10/13/2013
- Re: [Coq-Club] Package managing, Adam Chlipala, 10/13/2013
- Re: [Coq-Club] Package managing, Guillaume Melquiond, 10/14/2013
