coq-club - Re: [Coq-Club] Package managing
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Package managing
  • Date: Mon, 14 Oct 2013 15:16:21 -0400
Hi Thomas,
As I told you offline, I really believe that a package manager for Coq is a great idea, and that reusing opam makes sense, especially since many Coq developments contain ML plugins.
One common case when switching between Coq versions, download and install plugins is required and painful is for reviewing the development attached to a paper. Submitting a package instead, with all the required dependencies automatically installed, would probably save a great deal of time on the reviewers side.
I also expect to see more and more Coq developments relying on existing plugins (ssreflect, mtac,...) or combinations thereof, so the idea you mentioned of having persistent packages is probably worth exploring.
How in practice can we contribute new packages? Shall we fork cpam-repo and send pull requests?
Cheers,
Maxime.
On 10/12/2013 05:59 PM, Thomas Braibant wrote:
Hi list,
Last summer, I have been playing around a prototype package manager
for Coq. It is really a prototype and not ready for public consumption,
but it raised some interesting questions that need feedback.
The main ideas behind this prototype are 1) to be able to "switch"
between various versions of Coq, without having to
recompile/reinstall/handle symlinks by hand in any way; 2) to have a
unified way to find out what packages (that is, libraries, plugins,
fancy developments) are available for a given version of Coq; 3) to
get this prototype working with as little work as possible.
My solution to 1), 2) and 3) was to hack opam, the OCaml package
manager, to use it to handle Coq installations rather than OCaml
installations. Many thanks to ocamlpro for the brilliant tool that
opam is.
Now for the questions/request for comments.
* What about camlp4/camlp5?
Some packages (ssreflect 1.5rc1) do not compile if Coq was not
compiled with camlp5. I do not know of packages that require camlp4
specifically. Is there a good reason to handle both, or should
camlp5 be mandatory?
* Build systems
All packages I know of either use hand-written makefiles, or
coq_makefile generated one. Do you use something fancier?
* Installation of packages
Some packages are meant to be installed "locally". That is, they ask
the user to add a few cryptic commands to files, like:
Add Rec LoadPath "<dir>" as FooBar.
The problem with that is that it makes for non-portable
developments. It seems a rather fragile way to mark dependencies on
packages, and prone to break if one distribute files: there is no
reason that the <dir> path I use will be valid on someone else's
computer.
Then, coq_makefile generates Makefiles with an "install target" that
copy required files (plugins and .vo) to coq/user-contrib/foobar/
(where foobar is the name of the package). This seems portable,
since coqtop will look there upon "Require".
Is there any reason not to make this mandatory for packages? It
would make for an easy uninstall procedure, since it suffices to
remove the foobar directory to remove the foobar package. (I am not
speaking of dependencies between packages here, because this is
nicely handled by the prototype).
* Coq contribs, and packages in the wild
Coq contributions housed at http://coq.inria.fr/pylons/contribs made
for a mixed experience when I tried to package some of them. Some
work out of the box, once you figure what are the INSTALL steps.
Some are harder to handle. For instance, the ergo contrib has its
dependencies over other contribs built in its makefile, which
requires some work (it is not an "out-of-the-box" experience).
Then, there are some outstanding works that are not present there at
all, or that are old versions of things. I spent some time trying to
find out packages in the wild, but this is a place where help is
needed. If you have a package, and you think it could be cool to add
it to this prototype package manager, please, send me an email.
* (Simplifying) design decisions.
First, if you would be happy with recompiling everything
anytime you switch from compilers to compilers, there is no need for
a dedicated package manager, you can use opam readily for that, with
the right list of packages. Yet, I really think that we want some
"persistent" coq switches: switching from coq vA to coq vB makes it
possible to install packages for vB, and come back to your coq vA
installation without having to recompile coq vA. (Personally, I used
to think that I would only ever use the latest Coq version, but it
is not the case anymore: sometimes, I use trunk, sometimes I use Coq
patched with mtac, sometimes, I use 8.4pl2 and so on.) So am I right
that we (the coq community) want some persistent switches?
Second, changing the underlying OCaml version will force the user to
recompile his Coq installations and packages. There may be a spot
for discussion here, because I think that vo's magic number depends
on the ocaml version, which may be too stringent. Yet, it is no big
deal, is it?
Third, after discussion with OCamlPro people, it seems that it could
be possible to enhance opam to be our Coq package manager (Coq
packages would get a special treatment). Would people be happy with
that kind of workflow? Or would you rather have a separate package
manager, maybe a fork of opam (which is what my prototype is)?
* compilers and packages.
So far, my list of packages and compilers are as follows.
aac_tactics.0.4 containers.2010 ergo.2010 mathcomp.1.5
color.09.09.2013 counting.2010 flocq.2.2.0 ssreflect.1.5
compcert.2.0 cybelle.1.2 interval.0.16.1
8.4.dev 8.4.pl1-mtac 8.4.pl2-mtac 8.4.pl2 trunk
If you have a package/a coq version that you would like to see on
this list, please let me know privately. Note that this list is the
product of a random process, and that some packages (some of my own even)
are not part of it yet. I think we really need to be
"consumer-driven" here [1].
(There might be a naming issue, because some packages are not
versioned officialy, and/or I mangled names. I think it is
not really important at this point, isn't it?)
To conclude this email, I think that building this list of packages and
compilers that can be installed in an automatic manner is an important
part of the job, and help is needed on that front. Then, there is the
actual code of the package manager: it seems that OCamlPro is willing
to help, and I would like personally to continue to work on it in my
spare time [2]. But if you want to help, please let me know.
Thomas
[1] For instance, on my todo list are the various libraries about separation logic
that I know of.
[2] Even if my spare time is a dwindling quantity recently.
