- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: Djamila Baroudi <baroudi.d7 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] FixePoint
- Date: Sun, 20 Oct 2013 22:13:26 +0200
Le 20 oct. 2013 à 21:58, Adam Chlipala <adamc AT csail.mit.edu> a écrit :
On 10/20/2013 03:56 PM, Djamila Baroudi wrote:what's means fixepoint and when can i use it?
It sounds like you should be reading some introduction to Coq instead of asking this question here. I'm also assuming you mean the keyword "Fixpoint" of Coq. It's one of the most central features, which any tutorial will explain.
I've discovered http://cel.archives-ouvertes.fr/docs/00/47/58/07/PDF/coq-hurry.pdf just know. There is only 6 pages there before getting to the Fixpoint question … Pretty cool
Any one of the "Other documentation" presented there : http://coq.inria.fr/documentation is really good
The CoqArt (the first one) has a french version. second and third one are more modern
Good luck :-)
Pierre B.
- [Coq-Club] FixePoint, Djamila Baroudi, 10/20/2013
- Re: [Coq-Club] FixePoint, Adam Chlipala, 10/20/2013
- Re: [Coq-Club] FixePoint, Pierre Boutillier, 10/20/2013
- Re: [Coq-Club] FixePoint, mukesh tiwari, 10/23/2013
