coq-club - Re: [Coq-Club] eq_rect_eq can be proved
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] eq_rect_eq can be proved
  • Date: Mon, 21 Oct 2013 02:05:33 +0100
Oops... My bad. I didn't realize JMeq_rect had been tampered with.
On Mon, Oct 21, 2013 at 1:53 AM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
On 10/20/2013 08:50 PM, Rui Baptista wrote:
I'm confused. Why does it say it can't be proved in chapter "Reasoning About Equality Proofs" of "Certified Programming with Dependent Types".
Require Import JMeq.
Definition jmeq_eq : forall (t1 : Type) (x1 x2 : t1), JMeq x1 x2 -> x1 = x2.
Proof.
refine (fun t1 x1 => _).
refine (JMeq_rect _ _).
refine eq_refl.
Defined.
Try running [Print Assumptions] on some of your definitions.  Even this first one is already depending on the axiom [JMeq_eq], which is used to define [JMeq_rect].
