- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: stolz+coq AT ifi.uio.no
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proving structural equality of dependent records in Coq
- Date: Mon, 21 Oct 2013 15:05:19 +0200
Well, it's pretty much how you guessed: you cannot prove wf1=wf2 without assuming a proof irrelevance axiom. You can do that by writing
Require Import Coq.Logic.ProofIrrelevance.
( http://coq.inria.fr/distrib/current/stdlib/Coq.Logic.ProofIrrelevance.html )
On 21 October 2013 13:36, <stolz+coq AT ifi.uio.no> wrote:
[My programmer instinct made me ask first on
http://stackoverflow.com/q/19479716/60462 -- apologies for missing out on the
coq-club so far!]
I have defined a simple structure:
Require Import Ensembles.
Record ConfigStructure {T:Type} : Type := mkCS {
E: Ensemble T;
C: Ensemble (Ensemble T);
CS_wf : forall x y, In _ C x -> In _ x y -> In _ E y;
rooted := In (Ensemble T) C (Empty_set T)
CS_wf enforces a semantic well-formedness property upon construction, based on
the two arguments. Now later, I need to compare two records for equality --
what do I with the proof-component?
I started out with the following---I guess the two well-formedness should also
occur on the lhs?
Lemma CS_split: forall T e1 c1 wf1 e2 c2 wf2,
e1 = e2 /\ c1 = c2 -> mkCS T e1 c1 wf1 = mkCS T e2 c2 wf2.
Proof.
intros.
destruct H as [He Hc].
destruct He; destruct Hc.
f_equal.
Abort.
which takes me up to:
T : Type
e1 : Ensemble T
c1 : Ensemble (Ensemble T)
wf1 : forall (x : Ensemble T) (y : T),
In (Ensemble T) c1 x -> In T x y -> In T e1 y
wf2 : forall (x : Ensemble T) (y : T),
wf1 = wf2
I guess proof irrelevance also comes into play?
Grateful for any advice,
Volker
- [Coq-Club] Proving structural equality of dependent records in Coq, stolz+coq, 10/21/2013
- Re: [Coq-Club] Proving structural equality of dependent records in Coq, Arnaud Spiwack, 10/21/2013
- Re: [Coq-Club] Proving structural equality of dependent records in Coq, Rui Baptista, 10/22/2013
- Message not available
- Re: [Coq-Club] Proving structural equality of dependent records in Coq, Rui Baptista, 10/23/2013
