- To: coq-club AT inria.fr
- Subject: [Coq-Club] "with Definition"s in module types
- Date: Wed, 23 Oct 2013 20:42:54 +0200
Hi,
I am having trouble using "with Definition" clauses in module types to give
definitions to fields whose types depend on earlier elements of the module
type. For example, I want to start with the following module type:
Module Type S1.
Parameter T : Type.
Parameter f : T -> T.
End S1.
Then I want to create a derived module type S2, where f is defined as the
identity function over T but T still does not have a definition; i.e.,
something like this:
Module Type S2 := S1 with Definition f := fun t => t.
If I write it like the above, Coq tells me it cannot infer the type of the
variable t. But I can't figure out how to refer to the type T of t! Neither of
the following work:
Module Type S2 := S1 with Definition f := fun (t:T) => t.
Module Type S2 := S1 with Definition f := fun (t:S1.T) => t.
Is there any way to get this to work without having to completely redefine S1?
Thanks,
-Eddy
- [Coq-Club] "with Definition"s in module types, Eddy Westbrook, 10/23/2013
