- To: Marcus Ramos <marcus.ramos AT univasf.edu.br>
- Cc: Abhishek Anand <abhishek.anand.iitg AT gmail.com>, Maxime Dénès <mail AT maximedenes.fr>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Qed takes long time
- Date: Tue, 29 Oct 2013 04:35:29 +0100
Le Mon, 28 Oct 2013 22:04:21 -0200,
Marcus Ramos
a écrit :
> Hi again,
> Thanks for the replies. Here is the Lemma (tries to prove the
> equivalence of the language generate by a single symbol regular
> expression and a single transition finite automata).
> Lemma re_fa_sym:
> forall c: ascii,
> exists f: f_automata,
> re_fa_equiv (re_sym c) f.
> Proof.
> intros.
> exists (a'''' c).
> case c as [[][][][][][][][]]; compute; trivial.
> Qed.
Did you really need to use the ascii type? Couldn’t you define your own
type? Your "case c as [[][][][][][][][]]; compute" is likely to be the
culprit as it generates 256 cases. With more smartness, this might be
dramatically reduced. Or maybe simply start with something like:
"intros c; exists (a''''' c); <unfold, cbv …, or compute so that each
occurrence of 'c' is a generalizable expression of the form "t c"
where 't' is some function>; generalize <t c>; clear c; intros tc;
destruct tc …"
> The function "re_fa_equiv" calls many other operations that I do not
> include here for the sake of space. Basically it converts the regular
> expression into a finite automata, and then does all necessary
> operations and checks in order to determine if they represent the
> same language - or not. A lot of operations indeed.
> I used "Show Proof", the proof term has a few thousand lines but I
> can´t save it. How do I handle this situation?
> Thanks again.
> Marcus.
> 2013/10/28 Abhishek Anand
> > You can do Show Proof just before Qed to get the exact term that
> > has to be typechecked at Qed (I think).
> > Trying to type-check parts of the proof-term might help in
> > isolating the problem.
> > -- Abhishek
> > On Mon, Oct 28, 2013 at 6:41 PM, Maxime Dénès
> > wrote:
> >> Hi,
> >> In theory, a one tactic script can generate an arbitrarily complex
> >> proof term (which is checked at Qed), so you should give more
> >> information (like the lemma and its proof) if you want some advice.
> >> Maxime.
> >> On 10/28/2013 06:35 PM, Marcus Ramos wrote:
> >>> Hi,
> >>> It takes a few minutes to run the demonstration of a lemma with a
> >>> few lines in it, but when it reaches "Qed", it takes more than 40
> >>> minutes just for it. Why is that so?
> >>> Thanks in advance,
> >>> Marcus.
- [Coq-Club] Qed takes long time, Marcus Ramos, 10/28/2013
- Re: [Coq-Club] Qed takes long time, Maxime Dénès, 10/28/2013
- Re: [Coq-Club] Qed takes long time, Abhishek Anand, 10/28/2013
- Re: [Coq-Club] Qed takes long time, Marcus Ramos, 10/29/2013
- Re: [Coq-Club] Qed takes long time, AUGER Cédric, 10/29/2013
- Re: [Coq-Club] Qed takes long time, Marcus Ramos, 10/30/2013
- Re: [Coq-Club] Qed takes long time, Daniel Schepler, 10/30/2013
