- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] universe inconsistency: constraints visualization
- Date: Wed, 30 Oct 2013 10:46:18 +0100
Hi Abhishek,
On 28 oct. 2013, at 23:11, Abhishek Anand
wrote:
> Hi,
> Debugging universe inconsistencies in large coq developments seems very
> painful.
> Is there a tool to help with this process?
Not at the moment…
> It seems that the standard way is:
> 1) Go through the thousands of lines that Print Universes outputs, and
> collect the "relevant ones"
> 2) Map the level numbers to back the occurrences of Type in the coq code
> 3) Reason about the level constraints for the associated typing rules in
> that code
> Has someone written a tool to partially automate this process and provide a
> more
> visual representation of the constraints?
> Ideally, I would like the tool to output a minimal graph that explains the
> inconsistency
> and the code associated with all the involved levels. Helpful names instead
> of numbers as levels would also be useful.
In principle, what you ask for is difficult but not impossible. In my branch
adding universe polymorphism, definitions/inductives carry not only the
constraints but also the universe levels they introduced, so you
could link each global universe level to its place of introduction (it might
be reused by other definitions
though). For the minimal graph, the universe inconsistency error carries the
cycle that would be created,
so you could easily recreate a minimal graph with just that information to
display. The main problem is,
that cycle might result from a combination of constraints whose source (a
subtyping in some typing derivation)
is not recorded. However, if a definition f introduces a constraint l < l',
then it will be declared in the
universe context associated to f, so you could crawl the global context to
find out where each atomic
constraint from the miminal graph comes from: take the minimal graph and
check if it implies at least one
constraint l < l' of f, if so, f is part of the "problem". If you're willing
to work on adding this I'd be
happy to help.
> (optional question: Wouldn't it be better to have the ability to explicitly
> provide universe levels(e.g. Nuprl), than to debug a complicated mess of
> constraints?)
Yes. However, cumulatively is still implicit (subtyping) so you'd still get
constraints.
Best,
-- Matthieu
- [Coq-Club] universe inconsistency: constraints visualization, Abhishek Anand, 10/28/2013
- Re: [Coq-Club] universe inconsistency: constraints visualization, Abhishek Anand, 10/29/2013
- Re: [Coq-Club] universe inconsistency: constraints visualization, Pierre-Marie Pédrot, 10/29/2013
- Re: [Coq-Club] universe inconsistency: constraints visualization, Matthieu Sozeau, 10/30/2013
