- From: Marcus Ramos <marcus.ramos AT univasf.edu.br>
- To: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Qed takes long
- Date: Wed, 30 Oct 2013 15:23:33 -0200
Hi Matthieu,
Sure, here it is:
Lemma re_fa_sym:
forall c: ascii,
exists f: f_automata,
re_fa_equiv (re_sym c) f.
Proof.
intros.
exists (a'''' c).
case c as [[][][][][][][][]]; compute; trivial.
Qed.
The function "re_fa_equiv" calls many other operations that I do not include here for the sake of space. Basically it converts the regular _expression_ "re_sym c" into a finite automata, and then does all necessary operations and checks in order to determine if they represent the same language - or not. A lot of operations indeed.
Regards,
Marcus.
2013/10/30 Matthieu Sozeau <matthieu.sozeau AT inria.fr>
Hi Marcus,
could you show us the demonstration in question?
Best,
-- Matthieu
On 28 oct. 2013, at 23:33, Marcus Ramos <mvmramos AT gmail.com> wrote:
> Hi,
> It takes a few minutes to run the demonstration of a lemma with a few lines in it, but when it reaches "Qed", it takes more than 40 minutes just for it. Why is that so?
> Thanks in advance,
> Marcus.
- [Coq-Club] Qed takes long, Marcus Ramos, 10/28/2013
- Re: [Coq-Club] Qed takes long, Matthieu Sozeau, 10/30/2013
- Re: [Coq-Club] Qed takes long, Marcus Ramos, 10/30/2013
- Re: [Coq-Club] Qed takes long, Cedric Auger, 10/30/2013
