Re: [Coq-Club] Writing a recursive function that's not quite structurally recursive?
- To: Erik Silkensen <eriksilkensen AT gmail.com>
- Cc: Chris Dams <chris.dams.nl AT gmail.com>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Writing a recursive function that's not quite structurally recursive?
- Date: Sat, 2 Nov 2013 18:21:00 +0000
If you can define it as a function, it should be possible and easier to define it as a relation.
Here's a proof of well founded induction that doesn't depend on Acc, and also another example of a function not structurally recursive on nat.
Axiom lt_0 : forall n1, n1 < 0 -> False.
Axiom lt_trans : forall n1 n2 n3, n1 < n2 -> n2 < S n3 -> n1 < n3.
Axiom ltb : nat -> nat -> bool.
Axiom ltb_minus : forall n1 n2, ltb n1 (S n2) = false -> n1 - S n2 < n1.
Definition nat_wf_rect : forall P1,
(forall n1, (forall n2 : nat, n2 < n1 -> P1 n2) -> P1 n1) ->
forall n1, P1 n1.
Proof.
refine (fun P1 H1 n1 => _).
refine (H1 _ _).
change ((fun n3 => forall n2, n2 < n3 -> P1 n2) n1).
refine (nat_rect _ _ _ _).
refine (fun n2 H2 => _).
refine (False_rect _ _).
refine (lt_0 _ _).
refine H2.
refine (fun n2 H2 n3 H3 => _).
refine (H1 _ _).
refine (fun n4 H4 => _).
refine (H2 _ _).
refine (lt_trans _ _ _ _ _).
refine H4.
refine H3.
Defined.
Inductive div_rel : nat -> nat -> nat -> Prop :=
| div_rel_0 : forall n1, div_rel n1 0 0
| div_rel_ltb : forall n1 n2, ltb n1 (S n2) = true -> div_rel n1 (S n2) 0
| div_rel_geb : forall n1 n2 n3, ltb n1 (S n2) = false ->
div_rel (n1 - (S n2)) (S n2) n3 -> div_rel n1 (S n2) (S n3).
Definition div_strong : forall n1 n2, {n3 | div_rel n1 n2 n3}.
Proof.
refine (nat_wf_rect _ _).
refine (fun n1 H1 => _).
refine (nat_rect _ _ _).
refine (exist _ _ _).
refine (div_rel_0 _).
refine ((_ : forall b1 : _, _ = b1 -> _) (ltb n1 (S n2)) eq_refl).
refine (bool_rect _ _ _).
refine (fun H3 => _).
refine (div_rel_ltb _ _ _).
refine H3.
refine (_ (H1 _ _ _)).
refine (sig_rect _ _).
refine (fun n3 H4 => _).
refine (div_rel_geb _ _ _ _ _).
refine H3.
refine H4.
refine (ltb_minus _ _ _).
refine H3.
Defined.
Definition div : nat -> nat -> nat :=
fun n1 n2 => proj1_sig (div_strong n1 n2).
On Sat, Nov 2, 2013 at 3:11 PM, Erik Silkensen <eriksilkensen AT gmail.com> wrote:
Ok, thanks. I don’t know if this makes a difference, but anyway for context my goal is to define a step-indexed semantics in Coq where one of the rules looks kind of like(forall k,k <= k’ ->eval term val k -> P) ->-----------------------------eval term val (S k')so there’s a premise with a negative occurrence of eval. I thought, if I can’t write this as an Inductive relation, maybe I could write it as a Fixpoint, where I could tell Coq k is the decreasing argument, and then that’s where I ran into wanting to recur with some k <= k’ and tried to extract that into the first code I sent.On Nov 2, 2013, at 6:58 AM, Chris Dams <chris.dams.nl AT gmail.com> wrote:Thanks for such a quick reply and for the pointer to well_founded_induction lt_wf. Does this mean I should be using the Fix tactic? Or Function or Program Fixpoint? I think I’m getting stuck on how syntactically it should look for this basic example. Thanks again.
I would not use fix or Fixpoint in that case. I would just apply well_founded_induction lt_wf by either using the apply tactic or providing it with arguments by typing them by hand.
- [Coq-Club] Writing a recursive function that's not quite structurally recursive?, Erik Silkensen, 11/02/2013
- Re: [Coq-Club] Writing a recursive function that's not quite structurally recursive?, Chris Dams, 11/02/2013
- Re: [Coq-Club] Writing a recursive function that's not quite structurally recursive?, Erik Silkensen, 11/02/2013
- Re: [Coq-Club] Writing a recursive function that's not quite structurally recursive?, AUGER Cédric, 11/02/2013
- Re: [Coq-Club] Writing a recursive function that's not quite structurally recursive?, Rui Baptista, 11/02/2013
- Re: [Coq-Club] Writing a recursive function that's not quite structurally recursive?, Adam Chlipala, 11/02/2013
