- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] No global reference exists for projection value
- Date: Wed, 06 Nov 2013 14:38:42 +0100
Oh, and the reason your structure is not used during inference might come from
the fact that vanilla Coq tactics (I mean, non ssreflect tactics) are not all
canonical structure enabled (or at least it used to be the case).
Please "Print Canonical Projections" to check if your structure is registered
for the "sort" projection, and try using refine instead of Coq's apply.
Again, it would be easier to understand with a full example.
Cyril
- [Coq-Club] No global reference exists for projection value, Christian Doczkal, 10/28/2013
- Re: [Coq-Club] No global reference exists for projection value, Beta Ziliani, 11/06/2013
- Re: [Coq-Club] No global reference exists for projection value, Cyril Cohen, 11/06/2013
- Re: [Coq-Club] No global reference exists for projection value, Enrico Tassi, 11/06/2013
- Re: [Coq-Club] No global reference exists for projection value / Packaged Classes, Christian Doczkal, 11/07/2013
