- To: Marcus Ramos <marcus.ramos AT univasf.edu.br>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Basic coqdep
- Date: Fri, 08 Nov 2013 10:42:01 -0500
On 11/08/2013 10:03 AM, Marcus Ramos wrote:
Thanks
Adam, but I still can´t make it. I´ll try to be more specific then:
I have
a file name "Automata.v" which is located at "C:\Users\Marcus
Ramos\Documents\UFPE\CIn\Doutorado\Tese\Current\Sources". This file
starts with the following lines:
Require
Import Ascii.
Require
Import String.
Require
Import NPeano.
Add
LoadPath "C:\Users\Marcus
Ramos\Documents\UFPE\CIn\Doutorado\Tese\Current" as Current.
I recommend never using "Add LoadPath." Essentially I'm suggesting ignoring source file management commands not described in that chapter of CPDT. This may be an unsatisfying answer from the standpoint of particular questions you have about those other commands, but I think it sets you on the best practical path. When I
execute "coqdep *.v" at Sources, I get the messages (besides others):
I suggest never running "coqdep" directly. I've never done it myself, so it's not just that I'm trying to discourage you from using an "advanced" feature until you've learned more. ;) coq_makefile encapsulates the important features nicely. |
- [Coq-Club] Basic coqdep, Marcus Ramos, 11/07/2013
- Re: [Coq-Club] Basic coqdep, Adam Chlipala, 11/08/2013
- Re: [Coq-Club] Basic coqdep, Marcus Ramos, 11/08/2013
- Re: [Coq-Club] Basic coqdep, Pierre Boutillier, 11/08/2013
