coq-club - Re: [Coq-Club] co-defining an Inducive + a Fixpoint
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: Andrew Cave <acave1 AT cs.mcgill.ca>
  • Cc: t x <txrev319 AT gmail.com>, Rui Baptista <rpgcbaptista AT gmail.com>, Jason Gross <jasongross9 AT gmail.com>, coq-club <coq-club AT inria.fr>, vincent rahli <vincent.rahli AT gmail.com>
  • Subject: Re: [Coq-Club] co-defining an Inducive + a Fixpoint
  • Date: Mon, 11 Nov 2013 23:26:42 -0500
How would one go about adding (simultaneous)Induction-Recursion to Coq?
Has someone already done some work in this direction?
We are in a situation where this trick does not work(because of jumping up universe levels).
(Even if it did work, the original Inductive recursive definitions seem much cleaner and easier to work with.)
I guess the result of http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.219.2442
that adding Induction-Recursion increases the proof-theoretic strength of a dependent type theory inductive types applies to Coq.
So, I would assume there is no way to encode "all" inductive-recursive definitions as Inductive definitions in Coq.
If induction-recursion can be added to Coq in a few days of work, I might prefer to do that instead of dealing with complicated approximations to the "naturally" inductive-recursive definitions that we are dealing with.
Could someone give us an idea about the work involved in implementing induction-recursion(IR) and where to start?
Also, since Prop was not accounted for in the consistency proof in the above paper, I wonder if Coq with Prop and IR is consistent.
(if not, is there a way to disable Prop?)
Thanks,
Abhishek and Vincent
