Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism
- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism
- Date: Wed, 20 Nov 2013 08:42:07 +0100
Hello Robbert and Cédric,
2013/11/20 AUGER Cédric
<sedrikov AT gmail.com>:
> Le Tue, 19 Nov 2013 22:03:16 +0100,
> Robbert Krebbers
> a écrit :
>> On 11/19/2013 08:27 PM, David MENTRÉ wrote:
>> > * Curry-Howard isomorphism: a very simple Coq theorem (on Boolean
>> > or integers) with associated proof, from which I could also
>> > generate OCaml code and show the Coq type.
>> What about something simple like:
>> Lemma minus : forall x y : nat, y <= x -> { z | x = y + z }.
>> Proof.
>> induction x as [|x IH].
>> { exists 0. omega. }
>> intros [|y] ?.
>> { exists (S x). omega. }
>> destruct (IH y) as [z Hz]. omega. exists z. omega.
>> Defined.
>> Extraction minus.
>> (** val minus : nat -> nat -> nat **)
>> let rec minus n y =
>> match n with
>> | O -> O
>> | S n0 ->
>> (match y with
>> | O -> S n0
>> | S y0 -> minus n0 y0)
Thanks Robbert, that seems a very fine example.
I had to add "Require Import Omega." to replay the proof. I needed to
remove "{" and "}" characters to replay the proof on Coq 8.3 (no issue
on 8.4).
> Be careful, Extraction is not Curry Howard isomorphism! (Well, it is
> not an isomorphism at all.)
So what would show Curry Howard isomorphism? "Show Proof." (just
before Defined.)?
Best regards,
david
- [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, David MENTRÉ, 11/19/2013
- Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, Daniel Schepler, 11/19/2013
- Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, Robbert Krebbers, 11/19/2013
- Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, AUGER Cédric, 11/19/2013
- Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, David MENTRE, 11/20/2013
- Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, Cedric Auger, 11/20/2013
- Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, Daniel Schepler, 11/22/2013
- Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, David MENTRÉ, 11/23/2013
- Re: [Coq-Club] Looking for simple examples of constructive logic and Curry-Howard isomorphism, Kristopher Micinski, 11/23/2013
