- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Cc: Yann Régis-Gianas <yrg AT pps.univ-paris-diderot.fr>
- Subject: Re: [Coq-Club] print coq proof states?
- Date: Thu, 21 Nov 2013 18:19:40 +0100
Dear Thorsten,
there is an easy way to incorporate proof states in the .v file as a
comment
(and even a key binding for doing that in proof-general, can’t remember which
as
it happened to me accidentally). Basically, you can put the generated text
inside
[[ ]] in the comment and get “nice" output. Not fully automatic but that’s
something.
I suppose the new coqdoc (Yann ?) is able to do better. coq-tex reprocesses
the
commands while (old) coqdoc is based on a lexer only (!).
Cheers,
— Matthieu
On 21 nov. 2013, at 13:19, Altenkirch Thorsten
<psztxa AT exmail.nottingham.ac.uk>
wrote:
> Thank you Nuno.
> I need something which works with latex. Basically an improved coq-tex :-)
> I need a bit more flexibitlity (I..e sometimes I want to display a prrof
> state and something I don't) and I would like something that looks a bit
> better. I was just wondering wether anybody has done something like this or
> has a good idea how to go about it. E.g. how does coq-tex work?
> Cheers,
> Thorsten
> From: Nuno Gaspar
> <nmpgaspar AT gmail.com>
> To: Thorsten Altenkirch
> Cc:
> "coq-club AT inria.fr"
> Hello,
> Not exactly what you want but you may wanna check Proviola [1]. It may be
> what you want if you are willing to distribute html files for your course
> support material.
> [1] http://mws.cs.ru.nl/proviola/
> 2013/11/19 Altenkirch Thorsten
>> Hi,
>> I'd like to revise my lecture notes (for my course Introduction to formal
>> reasoning) and explain some coq proofs referring to the current proof
>> state. Hence I am looking for some software support to do this easily:
>> ideally a tool (maybe somebody already made something for this purpose) or
>> some suggestion how to make one (without too much effort). I want to
>> insert these annotated proof scripts into a latex document.
>> I know ideally this shouldn't necessary and people should just step
>> through the proof interactively. However, I find often people (especially
>> students) don't do that and it seems better if one could just insert proof
>> state and comments and certain points in a proof.
>> I have been using coq-doc to produce html and latex but as far as I know
>> there isn't a way to insert the proof state into the documents produced by
>> coqdoc. There is also coq-tex which sort of does what I want but too much
>> of it and the output is really ugly. Maybe I need to post process coq-tex
>> output? Or can I use coqtop directly?
>> Cheers,
>> Thorsten
>> P.S. Apologies for not being able to give a link to my course but my
>> university decided to disable anonymous login for moodle which means that
>> nobody from outside can look at our courses. We are still arguing with
>> them.
>> This message and any attachment are intended solely for the addressee and
>> may contain confidential information. If you have received this message in
>> error, please send it back to me, and immediately delete it. Please do
>> not use, copy or disclose the information contained in this message or in
>> any attachment. Any views or opinions expressed by the author of this
>> email do not necessarily reflect the views of the University of Nottingham.
>> This message has been checked for viruses but the contents of an
>> attachment may still contain software viruses which could damage your
>> computer system, you are advised to perform your own checks. Email
>> communications with the University of Nottingham may be monitored as
>> permitted by UK legislation.
> Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600
> dollars last year.
> Marge: Bart! Don't make fun of grad students, they just made a terrible
> life choice.
> This message has been checked for viruses but the contents of an attachment
> may still contain software viruses which could damage your computer system,
> you are advised to perform your own checks. Email communications with the
> University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club] print coq proof states?, Altenkirch Thorsten, 11/19/2013
- Re: [Coq-Club] print coq proof states?, Nuno Gaspar, 11/20/2013
- Re: [Coq-Club] print coq proof states?, Altenkirch Thorsten, 11/21/2013
- Re: [Coq-Club] print coq proof states?, Abhishek Anand, 11/21/2013
- Re: [Coq-Club] print coq proof states?, Matthieu Sozeau, 11/21/2013
- Re: [Coq-Club] print coq proof states?, Daniel Schepler, 11/21/2013
- Re: [Coq-Club] print coq proof states?, Kristopher Micinski, 11/21/2013
- Re: [Coq-Club] print coq proof states?, Adam Chlipala, 11/21/2013
