coq-club - [Coq-Club] Can't use ocaml REPL and other tools with Coq.
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Can't use ocaml REPL and other tools with Coq.
  • Date: Sat, 7 Dec 2013 20:39:39 +0400
Hello,
I just tried to run ocaml REPL and encountered the problem:
"Error: The files ./plugins/extraction/miniml.cmi and ./checker/term.cmi make inconsistent assumptions over interface Term."
I ran REPL with the following command:
~/kirillt/coq $ ocaml -rectypes `find -iname "*.ml" | xargs dirname | uniq | sed s/^/-I\ /g` plugins/extraction/extract_env.ml
(`find -iname "*.ml" | xargs dirname | uniq | sed s/^/-I\ /g` becomes "-I ./checker \n -I ./config ...")
Perhaps, some compiler extensions should be enabled (like -rectypes)?
Also, I encountered the same problem when I tried to use "merlin" plugin for vim.
And maybe my recent issue with ocamldebug is related, too?
The project is build from trunk (last commit is 28 November by xclerc).
Sincerely,
Kirill Taran
