coq-club - Re: [Coq-Club] Going from \/ to +
  • To: Andrej Bauer <andrej.bauer AT andrej.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Going from \/ to +
  • Date: Sun, 8 Dec 2013 16:38:33 -0500
Indeed, if you have constructive definite description (which is, I think, the same as assuming the elim rule for hProp), this is doable:
Set Implicit Arguments.
Require Import Description.
Lemma this_is_true : forall p q : Prop, (forall x y : p, x = y) -> (forall x y : q, x = y) -> p \/ q -> ~ (p /\ q) -> {p} + {q}.
Proof.
  intros p q p_irr q_irr H H0.
  refine (@proj1_sig _ (fun _ => True) _).
  apply constructive_definite_description.
  destruct H as [x|x];
    [ (exists (left x))
    | (exists (right x)) ];
    split; trivial;
    intros [y|y] [];
    f_equal;
    first [ apply p_irr
          | apply q_irr
          | destruct (H0 (conj x y))
          | destruct (H0 (conj y x)) ].
Defined.
-Jason
On Sun, Dec 8, 2013 at 2:58 PM, Andrej Bauer <andrej.bauer AT andrej.com> wrote:
I thought so, and I do not see how to play a trick with singleton
elimination to get it done (that's the only chance to eliminate from
Prop into Type, as far as I know). In homotopy type theory this should
be doable. There \/ is interpreted as the propositional truncation of
With kind regards,
Andrej
