- From: Christopher Ernest Sally <christopherernestsally AT gmail.com>
- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] using the left conjunct (already proved) to solve the right
- Date: Wed, 25 Dec 2013 06:40:36 +0800
Thanks троль and Jason.
Yes, indeed. However that doesn't quite suit my purposes as I won't know in what order the students will want to prove the goals, and so even if I prove that family of lemmas (for different arity and order) I wouldn't know which to apply.
I just wanted to confirm that there's no easy way to do this (didn't find anything in the reference manual). I guess I'll try to write a tactic.
Best
Chris
On 25 December 2013 06:38, Christopher Ernest Sally <christopherernestsally AT gmail.com> wrote:
I just wanted to confirmOn 25 December 2013 06:31, Jason Gross <jasongross9 AT gmail.com> wrote:
It should be easy to prove a lemma "L /\ (L -> R) -> L /\ R". Then you can just apply this lemma before you split. (You can prove similar lemmas for other numbers of goals.)
-Jason
On Dec 24, 2013 4:58 PM, "Christopher Ernest Sally" <christopherernestsally AT gmail.com> wrote:
Hi allSay I have some goal of the form Hyp1 -> Hyp2 -> Hyp3 -> L /\ R and I split and then prove L. Now I have Hyp1-3 above the bar, is there any simple way to add L to the current context?More generally, if I have several sub-goals g_1, g_2 ... g_n, how can I add a g_i to the context once I prove it?I know this is being slightly troublesome, and normally I would not bother, only. I'm trying to write some material intended for freshmen and hence can't expose too much of Coq's inner workings to them.
Warm regards
Chris
- [Coq-Club] using the left conjunct (already proved) to solve the right, Christopher Ernest Sally, 12/24/2013
- Re: [Coq-Club] using the left conjunct (already proved) to solve the right, Jason Gross, 12/24/2013
- Re: [Coq-Club] using the left conjunct (already proved) to solve the right, Christopher Ernest Sally, 12/24/2013
- Re: [Coq-Club] using the left conjunct (already proved) to solve the right, троль, 12/25/2013
- Re: [Coq-Club] using the left conjunct (already proved) to solve the right, Terrell, Jeffrey, 12/25/2013
