- To: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] getting out of order output from coqdoc
- Date: Fri, 3 Jan 2014 19:27:37 -0500
I'm often running into situations where a definition A depends on some definition B and hence
A cannot be defined(in Coq) before defining B.
However, while communicating the idea to humans via coqdoc, a top down explanation is more suitable, i.e. the definition of B would seem boring/useless until the definition of A is shown to motivate it.Coqdoc does not seem to provide a way to output definitions and the associated comments in an order that is different that the order in which they appear in the .v file.
Is there an easy way to get around this limitation?Currently, I have to split the .v file such that the definitions of A and B are in different .v files. Then I include the output .tex files of coqdoc in the
desired order in the main .tex file.Thanks,
-- Abhishek
http://www.cs.cornell.edu/~aa755/
- [Coq-Club] getting out of order output from coqdoc, Abhishek Anand, 01/04/2014
- Re: [Coq-Club] getting out of order output from coqdoc, Vladimir Voevodsky, 01/04/2014
- Re: [Coq-Club] getting out of order output from coqdoc, Jason Gross, 01/04/2014
- Re: [Coq-Club] getting out of order output from coqdoc, Abhishek Anand, 01/04/2014
