- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Nested Fixpoint
- Date: Wed, 08 Jan 2014 17:20:11 +0100
On 08/01/2014 16:41, Terrell, Jeffrey wrote:
> Hi,
> It is possible to reorganise the following example (which is not meant to
> do anything useful) so that the definition of g is not contained within f?
> Inductive A : Set :=
> Build_A : list B -> A
> with B : Set :=
> Build_B : A -> B.
> Fixpoint f (a : A ) : list B :=
> match a with Build_A l =>
> (fix g (l : list B) : list B :=
> match l with
> nil => nil |
> b :: l' => b :: g l' ++ h b
> end) l
> end
> with h (b : B) : list B :=
> match b with Build_B a =>
> f a
> end.
Hi,
No, currently you can't. Nested inductive types require nested fix and
mutual inductive types require mutual fix. All you can do is write g
parameterized by h, before the mutual f and h.
Given the trouble we're having these days with the guard condition, it
is not sure we are going to consider more extensions before a thorough
check that it's OK, although the fix candidate is doing a significant
step towards allowing it.
Bruno.
- [Coq-Club] Nested Fixpoint, Terrell, Jeffrey, 01/08/2014
- Re: [Coq-Club] Nested Fixpoint, Bruno Barras, 01/08/2014
