- To: coq-club AT inria.fr
- Subject: [Coq-Club] Class implementation leaks
- Date: Tue, 14 Jan 2014 19:18:37 +0000
Hi all,
I am having problems with the implementation of class instances leaking
when I destruct things, as shown in the cut-down example below. My
intention was that subsequent code wouldn't be able to see the
implementation, so this makes proving some things impossible.
Is there a way I can stop the implementation leaking please?
Thanks
Ian
Require Import Equality.
Axiom P : Set.
Axiom Sequence : Set.
Class Cl (T : Type) : Type := mkCl {
invert : T -> T;
invertInverse : forall (p : T),
invert (invert p) = p
Inductive Catch : Type
:= MkCatch : forall (p : P), Catch
| Conflictor : forall (conflicts : Sequence), Catch.
Module impl.
Definition invertSequence (ps : Sequence)
: Sequence.
Admitted.
Definition invertInverseSequence : forall (s : Sequence),
invertSequence (invertSequence s) = s.
Admitted.
Instance ClSeq : Cl Sequence
:= mkCl Sequence invertSequence invertInverseSequence.
End impl.
Inductive CC : Catch -> Catch -> Catch -> Catch -> Prop
:= MkCC : forall (p : P)
(x y : Sequence),
x = invert y
-> CC (MkCatch p) (Conflictor x) (Conflictor x) (Conflictor x).
Lemma CatchCommuteUnique :
forall {p : Catch} {q : Catch}
{q' : Catch} {p' : Catch}
{q'' : Catch} {p'' : Catch}
(commute1 : CC p q q' p')
(commute2 : CC p q q'' p''),
True.
Proof with auto.
intros.
dependent destruction commute1.
dependent destruction commute2.
Now the implementation has leaked out: we have "impl.invertSequence"
rather than "invert":
H : impl.invertSequence y0 = invert y
apply (f_equal invert) in H.
rewrite invertInverse in H.
This therefore fails to rewrite "invert (impl.invertSequence y0)" to y0:
- [Coq-Club] Class implementation leaks, Ian Lynagh, 01/14/2014
- Re: [Coq-Club] Class implementation leaks, Erik Martin-Dorel, 01/14/2014
- Re: [Coq-Club] Class implementation leaks, Ian Lynagh, 01/14/2014
