coq-club - [Coq-Club] Recursively print terms used in a construction
  • To: Xavier Leroy <Xavier.Leroy AT inria.fr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Recursively print terms used in a construction
  • Date: Wed, 22 Jan 2014 03:21:32 -0500
Hi,
Xavier, you asked at the coq users meeting for a way to print all definitions that the type of a term depends upon.  After 2-3 hours of Ltac hacking, I have managed to implement a version in Ltac that does this (called [get_all_terms_and_types_recursively_in_type_of] below) (it doesn't pick up everything; it has trouble with dependent expressions under [forall] and under lambdas, and it won't pick up the types of constructors of an inductive type).  I've cc'd coq-club because I thought others might be interested in this.  It's rather ugly (and I can explain bits and pieces of it if desired, but I don't feel like documenting it all now; hacking in Ltac is a pain, especially when your tactics return terms, because then there's no good way to print out intermediate computation.)  The tactic returns a list, so it should be easy to feed it in to any procedure or other tactic, if, e.g., there's a plugin that will fetch the constructors of an inductive type.
The basic idea is that it gets terms and types by pattern matching on a term, and then puts them into a list, removes duplicates using ltac, and then recurses, cutting off recursion wherever it discovers a term that is already in the list (it's actually a bit less efficient than that, as it only looks at a much more local list, so expect slowdown sooner).
Here's the code:
Require Import List.
Record Dyn := dyn { ty : Type; elem : ty }.
Notation "` a" := (@dyn _ a) (at level 5).
Ltac head term :=
  match term with
    | ?f ?x => constr:(f)
    | _ => term
  end.
Ltac unif x y :=
  match x with
    | _ => let test := constr:(eq_refl : x = y) in
           constr:(true)
    | _ => constr:(false)
  end.
Ltac syntax_match x y :=
  match x with
    | y => constr:(true)
  end.
Ltac syntax_match_in a l :=
  match eval hnf in l with
    | nil => constr:(false)
    | ?b :: ?l' => let same := syntax_match b a in
                   match same with
                     | true => constr:(true)
                     | false => syntax_match_in a l'
                   end
  end.
Ltac filter_out a l :=
    | @nil ?T => constr:(@nil T)
                   let l'' := filter_out a l' in
                   match same with
                     | true => constr:(l'')
                     | false => constr:(b::l'')
                   end
  end.
Ltac uniq l :=
  lazymatch eval hnf in l with
    | ?b :: ?l' => let l'' := uniq l' in
                   let is_in_b_l'' := syntax_match_in b l'' in
                   lazymatch is_in_b_l'' with
                   end
  end.
Ltac get_all_terms term :=
  lazymatch term with
    | ?f ?x => let l1 := get_all_terms f in
               let l2 := get_all_terms x in
               let l1pl2 := constr:(l1 ++ l2) in
               uniq l1pl2
    | (fun x : ?T => ?f (@?P x)) => let l1 := get_all_terms f in
                                    let l2 := get_all_terms P in
                                    uniq l1pl2
    | (fun x : ?T => x) => get_all_terms T
    | (fun (x : ?T) (y : @?T' x) => @?P x)
      => let l1 := get_all_terms T' in
         uniq l1pl2
    | (fun (x : ?T) (y : @?T' x) => @?P y)
         uniq l1pl2
    | (fun (x : ?T) => forall (y : @?T' x), @?P x)
         uniq l1pl2
    | (fun (x : ?T) => forall (y : @?T' x), @?P y)
         uniq l1pl2
    | (fun x : ?T => ?f) => let l1 := get_all_terms T in
                            let l2 := get_all_terms f in
                            uniq l1pl2
    | (forall x : ?T, ?f (@?P x)) => let l1 := get_all_terms f in
                                     uniq l1pl2
    | (forall (x : ?T) (y : @?T' x), @?P x)
         uniq l1pl2
    | (forall (x : ?T) (y : @?T' x), @?P y)
         uniq l1pl2
    | (forall x : ?T, ?f) => let l1 := get_all_terms T in
                             uniq l1pl2
    | _ => let term' := (eval unfold term in term) in
           let terms := get_all_terms term' in
           constr:((@dyn _ term)::terms)
    | _ => (* uh oh, can't do any better *)
      constr:((@dyn _ term)::nil)
  end.
Ltac get_all_terms_in_types term :=
  let t := type of term in
  get_all_terms t.
Ltac get_all_terms_in_types_list_recursively l :=
    | @dyn _ ?x::?l'
      => let t' := (type of x) in
         let is_in_l' := syntax_match_in x l' in
         let same := syntax_match x Type in
         lazymatch (eval hnf in same) with
           | true
             => let l'' := get_all_terms_in_types_list_recursively l' in
                let ret := constr:(@dyn _ x::l'') in
                uniq ret
           | false
             lazymatch (eval hnf in is_in_l') with
               | true =>
                 let ret := constr:(@dyn _ x::@dyn _ t'::l'') in
                 uniq ret
               | false =>
                 let l''0 := get_all_terms_in_types x in
                 let l''1 := get_all_terms_in_types_list_recursively l''0 in
                 let l''2 := get_all_terms_in_types_list_recursively l' in
                 let ret := constr:(@dyn _ x::(l''1 ++ l''2)) in
                 uniq ret
             end
         end
  end.
Ltac get_all_terms_in_terms_and_types term :=
  let t := (type of term) in
  let l1 := get_all_terms term in
  let l2 := get_all_terms t in
  uniq l1pl2.
Ltac get_all_terms_in_terms_and_types_list_recursively l :=
    | @dyn _ ?x::?l'
           | true
             => let l'' := get_all_terms_in_terms_and_types_list_recursively l' in
                uniq ret
           | false
               | true =>
                 uniq ret
               | false =>
                 let l''0 := get_all_terms_in_terms_and_types x in
                 let l''0' := filter_out (@dyn _ x) l''0 in
                 let l''1 := get_all_terms_in_terms_and_types_list_recursively l''0' in
                 let l''2 := get_all_terms_in_terms_and_types_list_recursively l' in
                 uniq ret
             end
         end
  end.
Ltac get_all_terms_and_types_recursively_in_type_of term :=
  let l := get_all_terms_in_terms_and_types term in
  get_all_terms_in_terms_and_types_list_recursively l.
  get_all_terms_and_types_recursively_in_type_of t.
Definition eq' := @eq.
Goal True.
  let term := constr:(@eq' _ (0::1::nil) (0::1::nil)) in
  let l' := get_all_terms_in_terms_and_types_list_recursively l in
  idtac l'.
  (* (`eq'
 :: `eq
    :: `cons
       :: `S
          :: `0 :: `(@nil) :: `list :: `nat :: `Set :: `Prop :: `Type :: nil) *)
-Jason
  • [Coq-Club] Recursively print terms used in a construction, Jason Gross, 01/22/2014
