- To: "J. Ian Johnson" <ianj AT ccs.neu.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Stack overflow trying an encode/decode proof.
- Date: Thu, 23 Jan 2014 16:59:07 -0500 (EST)
Whoops, change the Prop in the motive to True.
ystael on #coq got this to go through with 8.4pl1, but my 8.4pl2 has a stack
overflow. Must be a bug.
-Ian
----- Original Message -----
Cc: "coq-club"
Sent: Thursday, January 23, 2014 4:33:12 PM GMT -05:00 US/Canada Eastern
Narrowed down the stack overflow to the following function, which I think
should be pretty innocuous.
Require Import Vectors.Fin.
Definition fin_decode1 (b : t 2) : True :=
match b as b' in (t n) return ((match n with
0 => (fun H : n = 0 => False)
| S n' =>
(fun H : n = S n' =>
Prop)
end) (eq_refl n))
with
F1 _ => I
| FS _ _ => I
end.
-Ian
To: "coq-club"
Sent: Thursday, January 23, 2014 4:21:44 PM GMT -05:00 US/Canada Eastern
Subject: [Coq-Club] Stack overflow trying an encode/decode proof.
I'm trying to formalize the notion of a finite type as one that is equivalent
to (fin n) for some n.
I'm using "t" from Vectors.Fin as "fin" in my code. The rest of this email is
coq code with comments describing what I tried and where things go wrong.
The gist is I tried a fancy motive to get around an ill-typed term after
destructing something, and since I apparently don't know quite well enough
what I'm doing, explosion.
(* Here's where I started: *)
Definition Finite (A : Type) : Prop :=
exists (n : nat) (f : A -> fin n), Bi_inv f. (* HoTT's Bi_inv with Prop
equality *)
Remark bool_fin : Finite bool.
Proof.
exists 2, (fun a : bool => if a then F1 else FS F1).
apply Quasi_bi_inv.
exists (fun f : fin 2 => match f with F1 _ => true | FS _ _ => false end).
(* destructing b leads to ill-typed term. *)
Abort.
(*So I try the encode/decode method with two codes for the two fins I need to
deal with:*)
Definition fin_code1 (b : fin 2) : Prop :=
match b with
F1 _=> b = F1
| FS _ _ => False
end.
Definition fin_code2 (b : fin 2) : Prop :=
match b with
F1 _=> False
| FS _ _ => b = FS F1
end.
Definition fin_encode1 (b : fin 2) (p : b = F1) : fin_code1 b.
unfold fin_code1; rewrite p; reflexivity.
Defined.
Definition fin_encode2 (b : fin 2) (p : b = FS F1) : fin_code2 b.
Defined.
(*All is well, so now I need decode functions.*)
(* How about this? Uncomment for the error. Basically, I can't have two
different types for H without a fancy motive.
Definition fin_decode1 (b : fin 2) (c : fin_code1 b) : F1 = b :=
(match b with
F1 _ => (fun (H : F1 = b) (H0 : fin_code1 F1) =>
H)
| FS _ _ => (fun (H : b = FS F1) (H0 : fin_code1 (FS F1)) =>
match H0 with end)
end (eq_refl b) c)
(* Let's try a fancy motive! I'm pretty sure this should work...
(match b as b' in (fin n) return (match b' with
F1 _ => F1 = b -> fin_code1 F1 -> F1
= b
| FS _ _ => b = FS F1 -> fin_code1 (FS
F1) -> F1 = b
end)
with
H)
match H0 with end)
end (eq_refl b) c).
Nope, the return type is a match, and I thus can't apply it to (eq_refl b).
What now?
Well, I wasn't sure whether to have b or b' in the return type, but it yelled
at me when I put b',
since I didn't have the fin type's index figured out. Let's try to do
something better about that.
(match b as b' in (fin n) return ((match n with
| S n' =>
(match b' with
F1 _ => (@F1 n') = b' ->
fin_code1 F1 -> F1 = b'
| FS _ _ => b' = FS (@F1 1) ->
fin_code1 (FS F1) -> F1 = b'
end))
end) (eq_refl n))
with
H)
match H0 with end)
end (eq_refl b) c).
(* STACK OVERFLOW! Well, I'm out of ideas. Better go to coq-club. Any
assistance is appreciated.
-Ian
- [Coq-Club] Stack overflow trying an encode/decode proof., J. Ian Johnson, 01/23/2014
- Re: [Coq-Club] Stack overflow trying an encode/decode proof., Daniel Schepler, 01/24/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Stack overflow trying an encode/decode proof., J. Ian Johnson, 01/23/2014
- Re: [Coq-Club] Stack overflow trying an encode/decode proof., Matthieu Sozeau, 01/24/2014
- Re: [Coq-Club] Stack overflow trying an encode/decode proof., Jason Gross, 01/24/2014
- Re: [Coq-Club] Stack overflow trying an encode/decode proof., J. Ian Johnson, 01/24/2014
