- To: Bruno Woltzenlogel Paleo <bruno.wp AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] eauto with unfold hints
- Date: Fri, 24 Jan 2014 12:09:27 -0800
Yes, this is normal; eauto and autounfold and autorewrite can share database names, but use non-overlapping sets of hints in those databases. You might want
Hint Extern 1 => unfold foo : mydb.
(Or any other number in place of 1.)
-Jason
On Fri, Jan 24, 2014 at 6:04 AM, Bruno Woltzenlogel Paleo <bruno.wp AT gmail.com> wrote:
Hi,I added some Unfold hints to a “mydb” hint database.Then I try “eauto with mydb.” but it doesn’t solve the goal.On the other hand, when I try “autounfold with mydb. eauto.” , the goal is solved.Is this normal?Is there a standard way to solve such goals with a single automation tactic? Or do I really need to use two tactics (autounfold followed by eauto) ?Best regards,Bruno
- [Coq-Club] eauto with unfold hints, Bruno Woltzenlogel Paleo, 01/24/2014
- Re: [Coq-Club] eauto with unfold hints, Jason Gross, 01/24/2014
