- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club AT inria.fr, Kenneth Roe <kendroe AT hotmail.com>
- Subject: Re: [Coq-Club] Progress theorem
- Date: Fri, 24 Jan 2014 17:28:48 -0800
Daniel: I'm relatively certain that would be true even if b always evaluates to true. Note that it is a progress theorem, not a termination theorem.
Kenneth: Will an induction on ceval c st st' not work?
-Andrew
On Jan 24, 2014 5:20 PM, "Daniel Schepler" <dschepler AT gmail.com> wrote:
I don't see how this could possibly be true if, for example, b always evaluates to true. Take this with a grain of salt as I'm not too familiar with this, but: I'd suppose that to prove a WHILE statement terminates, you typically give some well-founded ordering on states (for example by comparing the values of some measure function to nat), and then prove something like beval st b = true -> exists st', st' < st /\ ceval c st st'. Then the proof, roughly, would go by induction on (Acc (<) st): if beval st b = false, you use E_WhileEnd. Otherwise, if beval st b = true, you use the progress statement on c to get st', and since st' < st, the WHILE statement terminates with starting state st' by induction. Then the constructor E_WhileLoop gives WHILE terminating with starting state st.--Daniel ScheplerOn Fri, Jan 24, 2014 at 3:51 PM, Kenneth Roe <kendroe AT hotmail.com> wrote:
Consider the following definition of ceval and the progress theorem below.
Inductive ceval : com -> state -> state -> Prop :=
(*| E_Skip : forall st,
SKIP / st || st*)
| E_Ass : forall st a1 n x,
aeval st a1 = n ->
(x ::= a1) / st || (update st x n)
| E_Seq : forall c1 c2 st st' st'',
c1 / st || st' ->
c2 / st' || st'' ->
(c1 ;; c2) / st || st''
| E_IfTrue : forall st st' b c1 c2,
c1 / st || st' ->
(IFB b THEN c1 ELSE c2 FI) / st || st'
| E_IfFalse : forall st st' b c1 c2,
beval st b = false ->
c2 / st || st' ->
| E_WhileEnd : forall b st c,
(WHILE b DO c END) / st || st
| E_WhileLoop : forall st st' st'' b c,
c / st || st' ->
(WHILE b DO c END) / st' || st'' ->
(WHILE b DO c END) / st || st''
where "c1 '/' st '||' st'" := (ceval c1 st st').
Theorem cevalWhileProgress : forall b c w,
(forall st, exists st', ceval c st st') ->
w = (WHILE b DO c END) ->
(forall st, exists st', ceval w st st').
Proof.
(Note that auxiliary definitions come from the Software Foundations Imp.v source file)
What would be the best way of setting up a proof of this theorem? The ideal thing would be to do an induction on a hypothesis of type "ceval w st st'". However, this term is in the conclusion. Any alternative suggestions?
- Ken
- [Coq-Club] Progress theorem, Kenneth Roe, 01/25/2014
- Re: [Coq-Club] Progress theorem, Daniel Schepler, 01/25/2014
- Re: [Coq-Club] Progress theorem, Andrew Hirsch, 01/25/2014
