coq-club - [Coq-Club] Patterns in notation
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Patterns in notation
  • Date: Fri, 7 Feb 2014 17:00:37 +0000
  • Accept-language: en-GB, en-US
Hello all
I often find myself wanting to define notation that abstracts over match *patterns*, not just variables. I am assuming that this is not possible using the current mechanism; are there any plans to add it in future? A good example is the ssreflect extended if syntax (e.g. “if x is y::ys then ys else nil”) that is currently hardwired into ssreflect rather than defined using notation. A common idiom that I would like to define using notation is
trymatch x with p => e
which would expand to
match x with p => Some e | _ => None end
In other words, I want to write
Notation “’trymatch’ x ‘with’ p ‘=>’ e” := (match x with p => Some e | _ => None end) (p pattern)
or something similar.
-          Andrew.
