coq-club - Re: [Coq-Club] common declarations of module signature and module instance
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] common declarations of module signature and module instance
  • Date: Wed, 12 Feb 2014 01:49:49 +0100
Hi, I would do the following. This is a bit cumbersome but this is the
price of putting definitions in a module type in the current state of
coq modules. If one could import things from a module type into a
module, we could factorize things. I think Elie Soubiran did his phd
on this subject, the idea was that there is no real difference between
a module type and a module in a dependently typed language.
I don't know if there are better solution.
Module Type Sig.
Definition T : Type := nat.
Parameter f : T -> T.
Definition g (t : T) : T := f (f t).
End Sig.
Module Impl <: Sig.
Definition f (t : T) : T := t * 2.
End Impl.
You could make a functor building a sig from {T ; f } but you also end
up duplicating definitions between module and module type:
Module Type F.
Definition T: Type := nat.
End F.
Module IMPLF<:F.
End IMPLF.
Module Type Sig(A:F).
Import A.
End Sig.
Module IMPLSig <: Sig(IMPLF).
Import IMPLF.
End IMPLSig.
Best regards,
Pierre
2014-02-11 22:26 GMT+01:00 Kirill Taran
<kirill.t256 AT gmail.com>:
> Module Type Sig.
> End Sig.
> Module Impl <: Sig.
> End Impl.
