- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] COQ workshop
- Date: Wed, 12 Feb 2014 12:06:50 -0500
On 02/11/2014 08:43 PM, Kristopher Micinski wrote:
Out of curiosity, I may be missing the current one, but is there any
resource that systematically attempts to collect the more advanced
features of Coq? As an example, while working through SF and CPDT
will teach you a lot, when you hop into real developments you need to
learn a laundry list of other things, such as libraries (Penn's
metatheory library, SSReflect, etc...), lesser documented features
(type classes and coercions), and new theory (e.g., working with the
homotopy type theory branch).
I think it would be misleading to say that the elements you mention are essential for "real developments." I've only ever used one of them, and I actively recommend against using at least one of them, though I'll be tactful and not reveal which. :)
The one I've used is coercions, which I think is simple enough that the Coq reference manual makes for a good tutorial.
CPDT really is meant to cover all the material for "real developments" in Coq that is not easy to pick up from the Coq manual. Particular application domains have their own knowledge bases, but I think of all that as distinct from Coq as a tool.
- [Coq-Club] COQ workshop, Sebastien, 02/11/2014
- Re: [Coq-Club] COQ workshop, Greg Morrisett, 02/12/2014
- Re: [Coq-Club] COQ workshop, Kristopher Micinski, 02/12/2014
- Re: [Coq-Club] COQ workshop, Sébastien Fricker, 02/12/2014
- Re: [Coq-Club] COQ workshop, Adam Chlipala, 02/12/2014
