coq-club - Re: [Coq-Club] impossible branches in pattern matching
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] impossible branches in pattern matching
  • Date: Thu, 13 Feb 2014 17:26:59 -0800
And yet another possibility (using an inductively defined Prop which
is equivalent to the previous TagOfNode n = tag):
Inductive NodeHasTag : Node -> Tag -> Prop :=
| left_has_tag_L e : NodeHasTag (left e) L
| right_has_tag_R e : NodeHasTag (right e) R.
Program Definition Cast'' tag
(n:Node | NodeHasTag n tag) : Element tag :=
match tag with
| L => match n with
| left e => e
| right _ => !
end
| R => match n with
| left _ => !
| right e => e
end
end.
Solve Obligations using program_simpl;
match goal with
| H : NodeHasTag _ _ |- _ => inversion H
end.
Daniel Schepler
On Thu, Feb 13, 2014 at 4:53 PM, Daniel Schepler
<dschepler AT gmail.com>
wrote:
> For Cast, how about something like:
> Require Import Program.
> Definition TagOf (n:Node) : Tag :=
> match n with
> | left _ => L
> | right _ => R
> end.
> Program Definition Cast tag (n:Node | TagOf n = tag) :
> Element tag :=
> match tag with
> | L => match n with
> | left e => e
> | right _ => !
> end
> | R => match n with
> | left _ => !
> | right e => e
> end
> end.
> (* or *)
> Definition Cast' (n:Node) : Element (TagOf n) :=
> match n with
> | left e => e
> | right e => e
> end.
> Daniel Schepler
> On Thu, Feb 13, 2014 at 4:26 PM, Kirill Taran
> <kirill.t256 AT gmail.com>
> wrote:
>> Daniel,
>> That really works. But it is not obvious for me, why "fresh" function is
>> casted to proper type while given argument isn't.
>> What about Cast function, I can't imagine how to tie node and tag together
>> yet.
>> Sincerely,
>> Kirill Taran
>> On Fri, Feb 14, 2014 at 4:04 AM, Daniel Schepler
>> wrote:
>>> For the definition of Wrap, you need the "convoy pattern" described in
>>> CPDT to get m to be the right type inside the match:
>>> Definition Wrap {tag} (m : Element tag) : Node :=
>>> match tag return (Element tag -> Node) with
>>> | L => fun m => left m
>>> | R => fun m => right m
>>> end m.
>>> (And then, of course, you could optimize that to something like:
>>> Definition Wrap' {tag} : Element tag -> Node :=
>>> match tag (* return (Element tag -> Node) *) with
>>> | L => left
>>> | R => right
>>> end.
>>> Daniel Schepler
>>> On Thu, Feb 13, 2014 at 3:47 PM, Kirill Taran
>>> wrote:
>>> > I also tried (not very hard) to invent "opposite" of previous
>>> > definition:
>>> > Definition Wrap tag (m : Element tag) : Node :=
>>> > match tag with
>>> > | L => left m
>>> > | R => right m
>>> > end.
>>> > But that fails, too. (Coq expects m to be Element L instead of Element
>>> > tag.)
>>> > I definetely should to glance at CPDT, but hadn't time for that yet.
>>> > Sincerely,
>>> > Kirill Taran
>>> > On Fri, Feb 14, 2014 at 3:35 AM, Kirill Taran
>>> > wrote:
>>> >> Hello again,
>>> >> What about such piece of code?
>>> >> Inductive Tag := L | R.
>>> >> Definition Element tag :=
>>> >> match tag with
>>> >> | L => nat
>>> >> | R => bool
>>> >> end.
>>> >> Inductive Node :=
>>> >> | left : Element L -> Node
>>> >> | right : Element R -> Node.
>>> >> Definition Cast tag (n : Node) : Element tag :=
>>> >> match tag with
>>> >> | L => match n return Element L with left e => e end
>>> >> | R => match n return Element R with right e => e end
>>> >> end.
>>> >> Coq can't infer that there enough branches and complains on definition
>>> >> of
>>> >> Cast.
>>> >> Pierre,
>>> >> I didn't find how to launch code with absurd pattern (!), your example
>>> >> doesn't work for me.
>>> >> Have I to enable any settings?
>>> >> Sincerely,
>>> >> Kirill Taran
>>> >> On Fri, Feb 14, 2014 at 12:32 AM, Kirill Taran
>>> >> wrote:
>>> >>> Daniel,
>>> >>> Ow, I didn't try that; thanks.
>>> >>> Pierre,
>>> >>> Thanks for advices about return and !. By the way, I really noticed
>>> >>> that
>>> >>> the code I am working on now becomes pretty difficult in the sense
>>> >>> that I
>>> >>> have to do some manual work.
>>> >>> Maybe there are any libs like lenses for haskell? (For reducing
>>> >>> boilerplate, when you need to extract something from the bottom of
>>> >>> structure
>>> >>> with different dependencies.)
>>> >>> Sincerely,
>>> >>> Kirill Taran
>>> >>> On Thu, Feb 13, 2014 at 11:11 PM, Pierre-Marie Pédrot
>>> >>> <pierre-marie.pedrot AT inria.fr>
>>> >>> wrote:
>>> >>>> On 13/02/2014 19:54, Kirill Taran wrote:
>>> >>>> > But Coq complains about definition of Matching: it says that
>>> >>>> > pattern
>>> >>>> > matching is non-exhaustive and there are can be branches L right
>>> >>>> > and R
>>> >>>> > left. But we never can construct such objects. Why Coq can't infer
>>> >>>> > that?
>>> >>>> Because this is undecidable in general. You have to write out return
>>> >>>> clauses by hand when you start messing with dependent
>>> >>>> pattern-matching.
>>> >>>> Or you can use Program to do the dirty job for you.
>>> >>>> Program Definition Matching (n : Node) :=
>>> >>>> match n with
>>> >>>> | L left => True
>>> >>>> | R right => True
>>> >>>> | _ => !
>>> >>>> end.
>>> >>>> (Here '!' stands for the absurd case. Have a look at the generated
>>> >>>> term
>>> >>>> to understand how it works.)
>>> >>>> The more your inductives will be dependent, the more you will need to
>>> >>>> do
>>> >>>> things by hand. I recommend the reading of CPDT to get a handful of
>>> >>>> neat
>>> >>>> design patterns when programming with dependent types.
>>> >>>> PMP
