coq-club - [Coq-Club] on termination
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] on termination
  • Date: Fri, 14 Feb 2014 10:19:00 +0100
Hello.
Consider the following piece of code:
Inductive exp : Type :=
  | NFError    : exp
  | NF1        : exp
  | NF2        : exp
  | FunCallExp : nat -> exp.
Definition functions : Type := list (nat * exp).
Function beq_nat (n m:nat) := true.
Function get_fun (n:nat) (functions:list (nat * exp)) :=
  match functions with
    nil              => NFError
  | cons (m, expr) r => if beq_nat n m then expr else get_fun n r
 end.
Fixpoint reduce_exp expr store {struct expr} :=
  match expr with
  | NFError   => nil
  | NF1       => cons 1 nil
  | NF2       => cons 2 nil
  | FunCallExp n =>
       let funexpr := get_fun n store in
       reduce_exp funexpr store
  end.
As you've guessed the last function intends to reduce the given _expression_, yet we face a termination problem: on the last match branch we perform a recursive call on funexpr, which is not a subterm of expr. Indeed, it doesn't typecheck.
What is the easiest way to tell Coq that this indeed terminates, by say, assuming that the reduction of 'get_fun n store' never contains a FunCallExp ?
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
