coq-club - [Coq-Club] Recursion on second component of subset type
  • From: Anders Lundstedt <anders AT anderslundstedt.se>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Recursion on second component of subset type
  • Date: Sat, 15 Feb 2014 01:22:21 +0100
Dear all,
I am trying to define a realizability relation for a first order
theory. Basically, I need to define a relation by recursion on
formulas of the theory. Below is a (hopefully not oversimplified)
example of what I am trying to achive. My questions:
1. Are there better approaches? (For example maybe it is better to use
Coq only as metatheory with which to formalize first order logic?)
2. How do I define the realizability relation so that Coq accepts it?
The example (pastebin: http://pastebin.com/tQC4KGJj):
Parameter A : Type.
(* imagine that A has pairing and think of these as projections, if you want
to
make sense of the realizability definition below *)
Parameter p0 p1 : A -> A.
Inductive is_A_atom : Prop -> Prop :=
| eq_false : is_A_atom False
| eq_atom (a b : A) : is_A_atom (a = b).
Inductive is_A_formula : Prop -> Type :=
| atom_formula P : is_A_atom P -> is_A_formula P
| and_formula P Q : is_A_formula P -> is_A_formula Q -> is_A_formula (P /\
Q).
Definition A_formulas := {P : Prop & is_A_formula P}.
(* gives recursive call has principal argument ... not equal to subterm of P
Fixpoint realizes (P : A_formulas) : A -> Prop := fun a =>
let (P, pf) := P in match pf with
| atom_formula _ _ => P
| and_formula P Q pf_P pf_Q => realizes (existT _ P pf_P) (p0 a) /\
realizes (existT _ Q pf_Q) (p1 a)
end.
(* this is the form I would prefer, this gives "cannot guess decreasing
argument of fix". I guess this is caused by the above error *)
Fixpoint realizes' (a : A) (P : A_formulas) : Prop :=
| and_formula P Q pf_P pf_Q => realizes' (p0 a) (existT _ P pf_P) /\
realizes' (p1 a) (existT _ Q pf_Q)
end.
Best regards,
Anders Lundstedt
