Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?
- To: Ömer Sinan Ağacan <omeragacan AT gmail.com>
- Cc: coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?
- Date: Sun, 16 Feb 2014 13:09:47 +0100
Le Sun, 16 Feb 2014 13:35:28 +0200,
Ömer Sinan Ağacan
a écrit :
> I don't understand how is that supposed to work.
> assert (S (length tl) = S (n - 1)). f_equal.
Sorry I misunderstood your original problem.
You wanted "f x = f y -> x = y", while I believed you wanted "x = y ->
f x = f y"
> This just adds same goal one more time to my list of goals. e.g. I had
> this as a goal:
> Goal 1) length tl = n - 1.
> Now I have this
> Goal 2) length tl = n - 1.
> Ömer Sinan Ağacan
> http://osa1.net
> 2014-02-16 0:18 GMT+02:00 AUGER Cédric
> <sedrikov AT gmail.com>:
> > Le Sat, 15 Feb 2014 23:29:23 +0200,
> > Ömer Sinan Ağacan
> > a écrit :
> >> Hi all,
> >> Let's say I have `length tl = n - 1` as goal and `H: n <> 0`. Can I
> >> apply same constructor/function to both sides of the equation in
> >> goal? Like applying S and having:
> >> Is this possible? If not, why?
> > It is possible, trivial and you do not even require H.
> > Here, "f_equal" would be enough (assert (S (length tl) = S (n-1)).
> > f_equal.). There are numerous other ways to do it.
> >> Thanks!
> >> Ömer Sinan Ağacan
> >> http://osa1.net
- [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, Ömer Sinan Ağacan, 02/15/2014
- Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, AUGER Cédric, 02/15/2014
- Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, Ömer Sinan Ağacan, 02/16/2014
- Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, AUGER Cédric, 02/16/2014
- Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, Vilhelm Sjöberg, 02/15/2014
- Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, Abhishek Anand, 02/16/2014
- Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, Robbert Krebbers, 02/16/2014
- Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, Mitchell Wand, 02/16/2014
- Re: [Coq-Club] Applying a constructor/function to both sides of an equation -- is this possible?, Jason Gross, 02/16/2014
