coq-club - Re: [Coq-Club] Maximally inserted implicit arguments
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Maximally inserted implicit arguments
  • Date: Wed, 19 Feb 2014 06:45:04 -0500
http://coq.inria.fr/refman/general-index.html says:
The latter (http://coq.inria.fr/refman/Reference-Manual022.html#hevea_default881) is the command.
-Jason
On Wed, Feb 19, 2014 at 6:35 AM, Frédéric Blanqui <frederic.blanqui AT inria.fr> wrote:
Great. Thank you!
The command "Context" does not appear in the index. :-(
Is it documented somewhere?
Le 19/02/2014 19:29, Jason Gross a écrit :
Context {var : type}.
Alternatively, use [Global Arguments lemma {var}.] after you close the section.
-Jason
On Wed, Feb 19, 2014 at 6:08 AM, Frédéric Blanqui <frederic.blanqui AT inria.fr> wrote:
Hello.
Is there a way to tell Coq that some section variable should be declared as a maximally inserted implicit argument when the section is closed?
Regards,
Frédéric.
