- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] modules unfolding in extraction
- Date: Fri, 21 Feb 2014 14:29:23 +0100
If I remember correctly, extraction to Haskell does not produce modules (mainly because there is no module Type equivalent in Haskell), so if you do not really care of the target language, you might exploit it.
2014-02-21 14:05 GMT+01:00 Rui Baptista <rpgcbaptista AT gmail.com>:
Hi,Is [Parameter Inline] what you're looking for?Regards, Rui BaptistaOn Fri, Feb 21, 2014 at 12:56 PM, Kirill Taran <kirill.t256 AT gmail.com> wrote:
Hello.
Is it possible to configure extraction such way that all modules will be eliminated from extracted code and parameters of them will be replaced with explicit extra arguments to functions?
E.g. this:Module Type T.Parameter P : Set.End M.(* In one file: *)Module N := T nat. Import N.Definition f : P := 1.
(* In other file: *)Module B := T bool. Import N.Definition f : P := true.must become this:(* In one file: *)Definition f : nat := 1.Definition f : bool := true.
Sincerely,
Kirill Taran
.../Sedrikov\...
- [Coq-Club] modules unfolding in extraction, Kirill Taran, 02/21/2014
- Re: [Coq-Club] modules unfolding in extraction, Rui Baptista, 02/21/2014
- Re: [Coq-Club] modules unfolding in extraction, Cedric Auger, 02/21/2014
- Re: [Coq-Club] modules unfolding in extraction, Kirill Taran, 02/22/2014
- Re: [Coq-Club] modules unfolding in extraction, Rui Baptista, 02/22/2014
