- To: coq-club AT inria.fr
- Cc: kirill.t256 AT gmail.com
- Subject: Re: [Coq-Club] modules and inductive types
- Date: Wed, 26 Feb 2014 06:09:25 +0100
Le Wed, 26 Feb 2014 05:39:11 +0400,
Kirill Taran
<kirill.t256 AT gmail.com>
a écrit :
> Hello.
> Is it possible to declare types inside module such way that I can
> pattern match on them outside of the module?
> (When I define module satisfying signature I must declare types with
> Definition or wrap Inductive/Record with it;
> that makes type content invisible to module users; I suspect that this
> behaviour is implemented intentionally.)
> Sincerely,
> Kirill Taran
I am not sure that is what you wish, but as far as I can remember
(sorry, I almost never use modules in Coq as I find them often less
convenient than records/type classes), there is a "with" syntax defined
in the reference documentation.
Without the "with", modules implementing a module type are made opaque,
so that all inductive types defined inside of it cannot be
pattern-matched, but with "with" you can require the type to be
transparent. Below is an example (without inductives). See the
reference manual for better explanations.
Module Type Cat.
Parameter Obj : Type.
Parameter Hom : Obj -> Obj -> Type.
Parameter Id : forall x, Hom x x.
Parameter Comp : forall z y, Hom y z -> forall x, Hom x y -> Hom x z.
Hypothesis LId : forall x y (f : Hom y x), Comp x x (Id x) y f = f.
Hypothesis RId : forall x y (f : Hom y x), Comp x y f y (Id y) = f.
Hypothesis Assoc
: forall t z (f : Hom z t) y (g : Hom y z) x (h : Hom x y),
Comp t z f x (Comp z y g x h) = Comp t y (Comp t z f y g) x h.
End Cat.
Module Opp (C : Cat) : Cat
with Definition Obj := C.Obj
with Definition Hom := fun x y => C.Hom y x
with Definition Id := C.Id
with Definition Comp := fun z y f x g => C.Comp x y g z f.
Definition Obj := C.Obj.
Definition Hom := fun x y => C.Hom y x.
Definition Id := C.Id.
Lemma LId : forall x y (f : Hom y x), Comp x x (Id x) y f = f.
Proof. intros; apply C.RId. Defined.(*for teaching purpose, use Qed in
practice*)
Lemma RId : forall x y (f : Hom y x), Comp x y f y (Id y) = f.
Proof. intros; apply C.LId. Defined.(*for teaching purpose, use Qed in
practice*)
Lemma Assoc : forall t z (f : Hom z t) y (g : Hom y z) x (h : Hom x y),
Proof. intros; symmetry; apply C.Assoc. Defined.(*for teaching purpose, use
Qed in practice*)
End Opp.
Fixpoint le (m n : nat) : Type :=
match m with
| O => unit
| S m => match n with
| O => Empty_set
| S n => le m n
end
end.
Fixpoint le_id (m : nat) : le m m :=
match m with
| O => tt
| S m => le_id m
end.
Fixpoint le_comp (m : nat) : forall n, le m n -> forall o, le n o -> le m o :=
match m as m return forall n, le m n -> forall o, le n o -> le m o with
| O => fun _ _ o _ => tt
| S m => fun n => match n with
| O => fun x => match x with end
| S n => fun H o => match o with
| S o => fun K => le_comp m n H o K
end end end.
Module Le. (*no ":Cat" type annotation, so what follows is transparent*)
Definition Obj := nat.
Definition Hom := le.
Definition Id := le_id.
Definition Comp z y f x g := le_comp x y g z f.
Proof.
intros x y f; revert x f; induction y; simpl; auto.
+ intros _ []; split.
+ intros []; simpl; auto.
intros [].
Defined. (*for teaching purpose, use Qed in practice*)
Proof.
intros [].
Lemma Assoc
Proof.
intros t z f y g x h; revert y h z g t f; induction x; simpl; auto.
intros [].
+ intros [].
+ intros y h []; simpl.
- intros [].
- intros z g []; simpl; auto.
intros [].
End Le.
Module Ge := Opp Le.
(*as Opp uses "with", Ge.Obj, Ge.Hom, Ge.Id and Ge.Comp
are transparent.
Ge.LId is not transparent as it is not "with" defined when Opp was
defined.
Eval compute in (Ge.Hom 3 0). (*reduced to "unit" as expected*)
Eval compute in (Le.LId). (*big ugly transparent term*)
Eval compute in (Ge.LId). (*small nice opaque term*)
- [Coq-Club] modules and inductive types, Kirill Taran, 02/26/2014
- Re: [Coq-Club] modules and inductive types, AUGER Cédric, 02/26/2014
- Re: [Coq-Club] modules and inductive types, Kirill Taran, 02/26/2014
- Re: [Coq-Club] modules and inductive types, Cedric Auger, 02/26/2014
