coq-club - Re: [Coq-Club] Unintended behavior with (operational) typeclass
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Unintended behavior with (operational) typeclass
  • Date: Sat, 01 Mar 2014 17:06:16 +0100
  • Openpgp: id=06A5351D
Le 28/02/2014 23:05, Matthieu Sozeau a écrit :
> Yes, that's the spirit. All defs are transparent except constants
> corresponding to the types of a definitional (one field, no curly braces)
> Class definition. E.g. Projections are transparent by default. The problem
> is that regular unification (outside tc resolution) will gladly unfold
> these definitional type-class constants, ignoring the transparency status,
> which is a bit of an abstraction leak. Iow, the typeclass system maintains
> its own transparency info.
> Hope that clears up any remaining confusion,
> -- Matthieu
Yes, it does, thanks Matthieu.
But I still have trouble while trying to use my class. It seems that the
transparency works only in one way, not the other. ( e.g. it doesn't unfold
in the term from the instance base, only in the term for which we try to
find an instance). Is it the normal behavior ?
Here is a small example :
Require Import Coq.Classes.Init.
Require Import Coq.Relations.Relation_Definitions.
Require Import Coq.Classes.Equivalence.
Class Equiv A := equiv: relation A.
Class test A (R:Equiv A).
Typeclasses Transparent Equiv.
(* This instance allows to guess the relation to use for R from the context
Instance equivalence_Equiv A R {Req : Equivalence R} : Equiv A :=R.
Typeclasses Transparent equivalence_Equiv.
Instance T A R {Req : Equivalence R} : test A _.
Goal forall A (R: relation A) {Req : Equivalence R}, test A R.
intros A R Req.
(* but here, the tc resolution fails to unify my R with the
(equivalence_Equiv A R Req) of the instance T. *)
typeclasses eauto.
Qed.
Cheers,
Julien
