- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] why simpl does not work in this case?
- Date: Mon, 03 Mar 2014 23:14:49 +0100
On 03/03/2014 22:57, Ömer Sinan Ağacan wrote:
Hi all,
I have this term as goal: http://lpaste.net/100661 and it looks
solvable once I can simplify it by doing beta-reduction and then
simplifying `match n with ...` term(it will become `match 0 with` once
beta-reduction is done) ..
Any ideas why I can't simplify this term, and what should I do to simplify it?
Coq never reduces a fix construct, unless the argument at the structurally-decreasing position is a constructor. (Otherwise, you would build an infinite sequence of reductions, which is bad.) So you have to destruct e sooner or later, so as to make a constructor appear there and reduce the fix.
Two approaches: either you destruct e and finish the proof for each of its constructors, or you replace the fix term by the reduced term you expect, and prove the equality by destructing e. Which approach to choose depends on which is the less painful: replicating the final proof 8 times or typing the replacing term.
Best regards,
Guillaume
- [Coq-Club] why simpl does not work in this case?, Ömer Sinan Ağacan, 03/03/2014
- Re: [Coq-Club] why simpl does not work in this case?, Guillaume Melquiond, 03/03/2014
