- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Performance of extraction with functors
- Date: Tue, 04 Mar 2014 07:38:05 -0500
We have a Coq development that extracts to about 20,000 lines of OCaml code. For some reason, running [Recursive Extraction] on the main definition takes several hours, and I'm writing to see if anyone has any insight into why. (We're using Coq 8.4pl2.)
My guess is that the blame belongs with the most unusual aspect of this development: it involves many functors (in the module-system sense).
Specifically, we want to build what is conceptually just a single functor, parameterizing a whole development over a few values. However, we want to divide the code amongst some tens of files, for engineering reasons. Each file that depends on other files contains a top-level functor whose body starts by instantiating other functors from the dependencies, with essentially the same parameters. Many files contain multiple nested invocations of other functors.
Could there be some nasty performance scaling that is superlinear in the pattern of functor-application nesting? We also see surprisingly high run time for other related commands, like [End] to finish a functor definition; but such commands are still orders of magnitude faster than recursive extraction (about a minute instead of several hours).
- [Coq-Club] Performance of extraction with functors, Adam Chlipala, 03/04/2014
